c notch
Front options. Depending on budget.
Crown vic lowering springs are available from Eaton Detroit and lower it 1.5-2" https://www.eatondetroitspring.com/a...rown-victoria/
or get some coil overs from multiple vendors. https://www.speedwaymotors.com/RideT...ic,338405.html
Rear Options
C Notch Options.
https://www.performanceonline.com/19...-c-notch-kits/
Or go buy some 3/16" flat bar approx 6" wide and get it cut to length or buy a 10' piece and cut to size and shape accordingly and also use it to build boxing plates.
You will also require shorter shocks on the rear once you get your rear axle flipped or spring packs modified.
D
Rear Options
C Notch Options.
D
shrekau
09-05-2012 06:03 AM
Ken2600
07-27-2008 08:45 PM
OneFine69
11-30-2004 09:23 PM
