wondering if these #'s show bad icp? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 09-14-2018, 09:59 AM
MONAVIERONJON
MONAVIERONJON is offline
MONAVIERONJON is starting off with a positive reputation.
truck runs and drives, has 188k on it. this is a motorcraft icp. Torquepro shows ipr at 7.7 to 8.1% at idle. Usually it should be about 14 i thought. hpop shows 523 to 592 . feels kinda sluggish. have a SES. Only real code i have is a 1316. I know its injectors, havent buzz tested it yet . Has new valve cover gaskets and IPR pigtail. any thought on the numbers bieng this low? thinking the OEM ICP needs replaced. Thankx, ROnjon
Old 09-14-2018, 03:29 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
If you ICP is 'bad' (I think) unplug it and see if your truck runs better... if it does (is it leaking oil at the connection?) then replace it.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
