5.4l 3v oil pressure - Page 2 - Ford Truck Enthusiasts Forums
Old 02-07-2019, 10:04 PM
rd65's Avatar
rd65
rd65 is offline
rd65 is starting off with a positive reputation.
I checked for codes this afternoon after work. No codes came up. I have a Actron CP9660 PocketScan Plus. Idle RPM in Park 602, in D 527. Last June, approx. 3500 miles ago I had a shop check out loud ticking noise. They found low oil pressure causing Phaser noise, they pulled the pan and cleaned sludge in oil pan that was blocking pick up. Approx 2000 miles later I replaced the coil packs. I used Pertronix from Summit. This is the second time these have been replaced. Truck has 138k miles on it. I bought as a 24 month lease return in Jan 2008 with 17k on odometer. Does this model have IAC? If so, where is it? 5.4 3V
Old 02-07-2019, 11:46 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is online now
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
No IAC, your 2006 uses a drive by wire system which has an electric throttle body motor and a separate throttle position sensor. The PCM cracks it open so it doesn't die at idle which does the job the IAC used to.
Old 02-07-2019, 11:58 PM
rd65's Avatar
rd65
rd65 is offline
Tell me this doesn't mean that fluctuating idle and dying is because of a failing PCM.
Old 02-08-2019, 12:01 PM
Rumble phish
Rumble phish is online now
Rumble phish is gaining momentum as a positive member of FTE.
It seems that my 2004 with the 5.4L 3V motor uses TBW and has a separate IAC valve (AutoZone lists the IAC valve for 2004 but not for 2006) I'll look under the hood later today to verify. I haven't had any issue so I haven't tinkered with it so far.
Perhaps the OP should check the function of the TPS? And also clean the throttle body and check the connections? Maybe a bad TB motor?
Old 02-08-2019, 12:04 PM
Rumble phish
I also found this article, which might be helpful...
https://www.engine-misfire.com/ford-...le-and-surges/
Old 02-09-2019, 06:35 PM
rd65's Avatar
rd65
rd65 is offline
Nice read, thanks. I will look into cleaning the throttle body here soon. I need to get my F350 going well enough to be my daily driver first though. Thanks for your time and effort on this. powersj sorry for high jacking your thread.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
