Brakes Dragging
Old Sep 11, 2018 | 10:56 PM
Redland1's Avatar
Redland1
Brakes Dragging
Hello.I have a 2017 with 62,000 miles and it feels like the brakes are dragging when taking off and also some vibration as well.Vibration is still present at highway speed,but don’t know if it’s the tires.Checked brake temps today after getting off the highway and rears were In the 120’s and front I the 190s.Any ideas what it can be? Thanks.
Old Sep 11, 2018 | 11:18 PM
HRTKD's Avatar
HRTKD
It's very normal for the front brakes to be higher temperature than the rear.
Is it possible that your front axle is engage? Maybe the hubs are locked into the manual position?
Old Sep 11, 2018 | 11:36 PM
Redland1's Avatar
Redland1
i just went outside to check the hubs an they are on Auto.
Old Sep 11, 2018 | 11:44 PM
HRTKD's Avatar
HRTKD
Bad u-joint
Bad wheel bearing - not likely as your temperatures aren't out of line
Bad emergency brake
Could be the brakes, but I would expect your temperature readings to be out of line at one wheel.
Old Sep 12, 2018 | 12:10 AM
Redland1's Avatar
Redland1
Bad u-joint
Bad emergency brake
Any idea how to test bearings on these trucks?
Old Sep 12, 2018 | 06:09 AM
Xwild's Avatar
Xwild
I'd be inclined to think u-joint as well, possilby one of the ones on the drive shaft.
Old Sep 12, 2018 | 07:26 AM
Mlambert22's Avatar
Mlambert22
I've got another question...
My front wheels have a abnormal amount of brake dust on them,I've noticed it since the first week I've had it and thought it was just because it is new and that it would work itself out. Now the truck has 4k on it (1k towing) how long should I wait before I take it in to have it looked at?
Old Sep 12, 2018 | 07:49 AM
Painted Horse's Avatar
Painted Horse
I've had both my 2011 and 2015 calipers freeze up and need to be replaced. The slide pin needs to be greased or it will corrode and freeze up the caliper
This happened at 60,000 - 70,000 miles on both of my previous trucks.
Check your calipers and make sure they are moving freely on the slide pin
Old Sep 12, 2018 | 08:08 AM
HRTKD's Avatar
HRTKD
The way I test bearings is to jack up the vehicle on the frame far enough for the tire to come off of the ground. With your hands at 9 and 3 positions try to move the tire left/right. Do the same at 12 and 6 positions. If there is movement - or especially clunking/metal sounds - then a bearing may be shot. Usually you hear it first while driving. Most often when turning left or right.
Old Sep 12, 2018 | 08:09 AM
HRTKD's Avatar
HRTKD
The sooner you take it in the better. A dragging brake pad can cause the rotor to overheat and warp.
Old Sep 12, 2018 | 08:54 AM
Redland1's Avatar
Redland1
I have been hearing a clunking when hitting a bump or turning.Will check the bearings today.
Old Sep 12, 2018 | 10:04 AM
Texmudder's Avatar
Texmudder
My 14 had a caliper lock up and eat a rotor.
Old Sep 12, 2018 | 10:09 PM
Redland1's Avatar
Redland1
I was able to jack up the front a little while ago and look at some things.First thing that I noticed was when spinning the wheels you could hear the brakes slightly dragging and there was a little bit of resistance.Dont know if a little bit of drag is normal.Also how much play is normal in the front end U joints going into each wheel? Mines had a little play on both sides.Passenger side front had a little popping noise when pulling left to right.
Old Sep 12, 2018 | 10:30 PM
HRTKD's Avatar
HRTKD
A small amount of drag and noise from the brakes when rotating the tire is normal. Excessive noise or a very stiff tire to rotate is not normal.
Old Sep 17, 2018 | 03:15 PM
Redland1's Avatar
Redland1
Starting to think it’s not the brakes.I’m hearing a growling noise.Today when going up some steep hills loaded the growling noise was more pronounced, so when I started the descent I put the truck in neutral and it coasted just fine with no noise.Put it back in gear and it started all over.
