Napkin in gas tank - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Napkin in gas tank
Old 09-10-2018, 01:39 PM
Db966
Db966 is offline
Db966 is starting off with a positive reputation.
Napkin in gas tank
Well this is embarrassing, last night after I filled up my gas tank I was drying the little bit of fuel that dripped. I have the 2018 5.0 that doesn’t have a cap so when I was drying around the opening a piece of the napkin smaller than my pinky nail got caught in the hole and I guess went into the tank. Is this something that the fuel filter will catch? Do I need to do anything? It’s a brand new truck and I’m still in the stage where I worry about the little things. Thanks in advance for the advice.
Old 09-10-2018, 01:42 PM
Tedster9's Avatar
Tedster9
Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
I'd start shopping for a new truck if I were you.
Old 09-10-2018, 02:05 PM
wgotthardt
wgotthardt is offline
wgotthardt is gaining momentum as a positive member of FTE.wgotthardt is gaining momentum as a positive member of FTE.
Depends on the brand of napkin.
Old 09-10-2018, 02:17 PM
Db966
Db966 is offline
hahaha yeah I know
Old 09-10-2018, 02:25 PM
onug's Avatar
onug
onug is offline
onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.onug has a great reputation on FTE.
Why not put a similar size piece into a cup of gas and see what happens. Maybe nothing. But I’d be concerned that it would dissolve a bit and release small bits of fiber or “goop” that will mess with the injectors.
Maybe the bigger question is will your dealership warranty a rebuild if they determine it was “bad fuel”.
Old 09-10-2018, 06:33 PM
Kingofwylietx
Kingofwylietx is online now
Kingofwylietx is gaining momentum as a positive member of FTE.Kingofwylietx is gaining momentum as a positive member of FTE.
I wouldn’t worry about it. That is literally what the fuel filter is for. The micron size of things that will pass through the fuel filter shouldn’t present any issue for the injectors (which are very high pressure and won’t blink at a fiber).
Try to be more vigilant in the future, but I seriously wouldn’t sweat this....not even a tiny bit.
Old 09-10-2018, 06:54 PM
KJ Smith
KJ Smith is online now
KJ Smith has a very good reputation on FTE.KJ Smith has a very good reputation on FTE.KJ Smith has a very good reputation on FTE.KJ Smith has a very good reputation on FTE.
IIRC, there is another set of doors a little further down.
It probably won't go into your tank...… until you fill up again......
Old 09-10-2018, 06:55 PM
85e150six4mtod
85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I am leaving the nozzle in there for 10 or more seconds after shutoff to avoid drips. Seems like it takes a while. YMMV.
Old 09-11-2018, 01:19 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
It's a tiny piece of napkin, don't worry about it. These trucks don't have fuel filters. There is a permanent filter sock and it won't get by it. Trust me, I find rocks and sand in the bottom of all our fleet trucks tanks and nothing gets to the filter sock.
Old 09-11-2018, 06:20 AM
Db966
Db966 is offline
that’s awesome thank you man
Old 09-11-2018, 07:14 AM
GABAR
GABAR is offline
GABAR is gaining momentum as a positive member of FTE.
More than likely it`ll just dissolved but I don`t think it`s something you should be too concerned about.
I`m not sure when you purchased it but congrats on the new truck.
Old 09-11-2018, 10:12 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
If it makes it to the pump I have no doubt the pump will obliterate it.
Old 09-14-2018, 05:09 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
sky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputation
I'll take the truck off your hands for $100 and you go buy a new one.
All kidding aside, stop worrying about it and just enjoy the new truck.
Old 09-14-2018, 05:20 PM
Db966
Db966 is offline
Thank you guys for the replies. It has made me feel better about the situation!
Old 09-14-2018, 07:11 PM
ford390gashog
To everyone that keeps saying it dissolved it didn't and won't. Cellulose stays together very well in fuel and oil and that's why fuel and oil filters are made from paper. The fuel filter sock sits in the pump assembly under a baffle. The baffles and height differences in the pump pick up work like a septic tank forcing all the solids to stay in the tank and not float into the pump cavity inlet.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
