HPOP Oil Lines
Old 09-08-2018, 03:06 PM
robjs111
robjs111 is offline
robjs111 is starting off with a positive reputation.
HPOP Oil Lines
Installing new HPOP on my 7.3 with 160k miles and not sure if oil lines should be replaced as well. There is an updated oil line version with 90 degree ends but run about $90 per side. Any suggestions would be appreciated.
Thanks.
Old 09-08-2018, 04:27 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Id reuse them BUT, buy 1 for spare
Old 09-08-2018, 04:37 PM
robjs111
robjs111 is offline
Any benefit to upgrading to newer design lines?
Old 09-08-2018, 04:38 PM
robjs111
robjs111 is offline
Old 09-08-2018, 04:40 PM
timmyboy76's Avatar
timmyboy76
Any benefit woild be that their new. Also, if stranded anywhere, a local shop can make a line IF they had the rated psi hose available(atleast 4000psi and 300*+)
Old 09-08-2018, 09:21 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
Never go by mileage on hoses, only by years HPOP hoses make a mess when they go and will leave you stranded, so if you are rocking the factory steel braded HPOP lines replace them.
Old 09-09-2018, 07:55 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
CNC Fab for the win. Just got my HPOP line upgrade kit yesterday. They look dope. Comes with all new fittings and gets rid of those stupid snap fittings. Those are the bane of our existence.
Old 09-09-2018, 09:05 AM
Sous's Avatar
Sous
Sous is offline
Moderator and SXE Junkie!
Sous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputation
I replaced my HPOP lines a while back with those fittings you linked and the updated OEM lines from RiffRaff. No regrets and I now have the confidence that they will be good for many years to come. The difference in the lines is dramatic when you compare them side by side.
Although, Corey at CNC Fabrication makes a great product and offers an alternative method of installing the lines. I would have no reservations about going the CNC Fab way next time in 150K miles...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
