No cruising tonight
Old 09-08-2018, 01:19 PM
Hotwolves5369's Avatar
Hotwolves5369
Hotwolves5369 is offline
Hotwolves5369 is starting off with a positive reputation.
No cruising tonight
Hey all, i have a 99 ford f350 that some dork cut all the wires under the air cleaner that go to the cruise control. Is there a pig tale i can get for that?
Old 09-09-2018, 10:28 AM
'88 E-350
'88 E-350 is offline
'88 E-350 has a very good reputation on FTE.'88 E-350 has a very good reputation on FTE.'88 E-350 has a very good reputation on FTE.
My first thought is a junkyard. Or repair what's there depending on how much, if any, they removed.
Old 09-09-2018, 12:13 PM
cleatus12r
cleatus12r is offline
cleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputationcleatus12r has a superb reputation
My first thought is that you don't have a 7.3L DIT.
No cruise control module on one of those.
Old 09-09-2018, 06:00 PM
'88 E-350
Hmmm, yea. I just assumed there was some wiring for the cruise system that he'd found in a schematic, but come to think of it, there's no reason for any wiring other than between the switches & ECM so you're probably right about being in the wrong forum.
Old 09-09-2018, 07:21 PM
Hotwolves5369
The ford dealership told me there was a module. Great!!! What forum should i be in if you don't mind me asking
Old 09-09-2018, 07:44 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud of
What year and engine do you have??
Old 09-09-2018, 09:34 PM
Hotwolves5369
It's a 99 7.3L powerstroke
Old 09-09-2018, 09:39 PM
viperman86's Avatar
viperman86
viperman86 is offline
viperman86 is starting off with a positive reputation.
I am assuming not ALL 99s came with CC
Old 09-09-2018, 09:56 PM
Colorado350
Whats the build date? You’re in the right spot...
cleatus12r
1999 Powerstroke.
YouDO NOT have a separate cruise control module. The wires from the steering wheel go straight to the PCM as there is zero mechanical link controlling fuel delivery. A picture of the area in question is in order.
Old 09-09-2018, 09:59 PM
cleatus12r
Not all of them did. However, it's little more than a steering wheel change and the addition of a short wiring harness to make it work.
Old 09-09-2018, 10:22 PM
Hotwolves5369
I'll take a pic and put it on here as soon as i can. It will be interesting to know what it is that has been cut. The truck does have some weird electrical crap going on as well. Like the headlights have to be on for the radio to work and then sometimes even then it shuts off on it's own. And the motor has to be running for windows to work. Could all ofnthis be the same deal as the cruise.
Old 09-09-2018, 10:24 PM
Hotwolves5369
I like to call it Christine. Lol
Old 09-09-2018, 11:16 PM
viperman86's Avatar
viperman86
sounds like the radio is not wired correctly to the usual switched 12v
Old 09-10-2018, 12:45 AM
'88 E-350
Sounds like some of the vehicles my parents had when I was little. Want wipers? Turn on the blower. Want headlights? Plush this wire into that hole. Want radio.....um, start by buying one, you can't afford it.
But back to you Hotwolves; there's no cruise control module, all accelerator action happens electronically whether you're using the pedal or the CC. A CC module is on engines with a mechanical throttle system, a cable or rod actuating a throttle body or carburetor. You have several gremlins so your CC could be related to one of those or not. If you can find out from the previous owner what he did to the wiring and why, when the CC stopped working, when the headlight/radio thing started, when the engine/window thing started; any history you can get might help.
Electrical is hard enough to diagnose hands on, it'll be a challenge to figure out remotely but there's a good chance someone will come along with some good help. Figuring out what was cut, and any other visible wiring issues you can find, will be crucial. In the meantime, verify that every fuse is good. Check them with a meter if you have one, sometimes they'll develop a micro-crack that goes unnoticed visually. Another suggestion is to not bother going back to that dealership for anything related to this truck. Anyone with an ounce of knowledge should know there's no CC module on this. Not to be taken as an insult to you please, you're allowed to be ignorant about the system, the dealership service department isn't.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
