Original engine/transmission
Old Sep 7, 2018 | 08:46 AM
K9bosnia's Avatar
K9bosnia
Trying to find out how to tell if 1960 F-100 I’m looking at still has original engine and transmission.....
Old Sep 7, 2018 | 01:32 PM
matthewq4b's Avatar
matthewq4b
We are going to need pics of the data plate engine and trans to tell you that.
Old Sep 8, 2018 | 08:32 AM
K9bosnia's Avatar
K9bosnia
Where is the data plate located?
Old Sep 8, 2018 | 09:10 AM
hotfalcoon's Avatar
hotfalcoon
Glove box door.
Old Sep 8, 2018 | 10:18 AM
K9bosnia's Avatar
K9bosnia
Ok, sorry for my ignorance, i get the plate part of it being in the glove box, but are there certain areas of the engine and transmission that I would need picture of....ie am I looking to match up serial numbers of some sort? I appreciate the help by the way!
Old Sep 8, 2018 | 03:35 PM
matthewq4b's Avatar
matthewq4b
Nope just over all pics so we can see what is installed is the same as it came with. Example crame from the factory with an I5 now has a V8. The trans as good a side shot as you can provide.
And if the truck is Canada built the data plate may be on the drivers door pillar. So check both locations.
Old Sep 12, 2018 | 04:51 PM
TA455HO's Avatar
TA455HO
Lead Gopher
With these old ford trucks there is nothing stamped on them to absolutely verify that a given engine and transmission were indeed the ones that it left the factory with. If the date codes on the cast parts line up from a few days to a few weeks before your truck was produced - that's about the best you can do. Dead giveaways would be date codes that were after your truck was produced or the year before is usually a bad sign, too.
Other than the Shelby Mustangs there were not too many other Fords from that era that did stamp a VIN number on the engine block. Possibly the Panteras.
General Motors did stamp a partial VIN number on the engine blocks and transmissions of a lot of their vehicles over the years so you can really get into the numbers matching thing with those a lot more so than most Ford vehicles. Other than the engine block and transmission and hidden body VIN stamps GM didn't stamp the VIN in other places that I've heard of. Differentials and carburetors, alternators and water pumps, etc. can all be identified for the most part similar to identifying a Ford part, but no VIN numbers on all the little stuff.
Chad
Old Sep 12, 2018 | 05:03 PM
matthewq4b's Avatar
matthewq4b
Chad
Ford of Canada did stamp engine serial numbers on the engines in this era but it had no relationship to the Vin/Chassis number. Not sure if the U.S did the same or not.
Old Sep 15, 2018 | 12:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1960 F100/350 could have a 223 1V I-6 or a 292 2V V8.
223 has the intake/exhaust manifolds located on the left (drivers) side of the engine.
292 commonly known as a Y block, has the distributor located behind the carburetor.
Truck registered by its specific VIN .. The 4th digit of the VIN is the engine code. C = 292 2V / J = 223 1V 1-6.
Oldschool2888
Aug 21, 2018 11:21 AM
Dennis-
Aug 4, 2018 08:32 AM
Pladsmand
Jan 15, 2018 01:42 AM
duphofff
Aug 5, 2010 07:39 PM
FordEdselFanatic
Feb 22, 2009 04:13 PM
