292 Stroked or 5.8 rebuild 1st gen lightning
Any experience with the following parts?
Please keep in mind, daily driver..... not a show truck. Some additional muscle, MPG increase, and reliability are focus, lol.
https://www.ebay.com/itm/1957-1960-F...0/192379327044
https://www.ebay.com/itm/Door-Window...k/192646931128
https://www.ebay.com/itm/5m-Big-D-sh...p/163169602891
Unless you are going to up grade the wiring for modern conveniences i would avoid the that set up and re get reproduction original harness yes more costly but they retain the factory look and are bolt in.
If you not going to rod the truck out use new reproduction harnesses
Proper reproduction door weather striping is avalible leave the sticky back stuff for someone else.
Found a junkyard with an AOD for $300, but the yards unsure of quality. Ill buy the rebuild kit, because "I dont know probably means" it needs it. There are tons of videos and how to's for rebuilding this transmission.
Junkyard is asking if I need the 10 1/4 or 11 1/4 tail. Any ideas? Is there a kit for this swap or part by part purchase? Any chance there's a write up I can't find?
pb0000
03-31-2019 12:32 AM
jeff hogan
04-01-2015 07:24 AM
shephard199
18
12-14-2011 09:09 PM
gusso
08-02-2008 11:37 PM
