Rear Brake Shoes
Old 09-28-2018, 09:10 AM
Suffolkman's Avatar
Suffolkman
Suffolkman is offline
Suffolkman has a good reputation on FTE.Suffolkman has a good reputation on FTE.
Hi, thought I would update and wind this thread up. When I removed the drivers side drum I discovered someone had fitted two shoes with full length linings. (the passenger side had 2 shorter lined shoes ). Not only that, but the wheel cylinder on the drivers side was leaking and had contaminated the shoe linings. SO, I replaced both wheel cylinders for new ones, and fitted new (correct ) shoes with leading & trailing linings. Problem over, the truck now stops straight and true without that locking problem. I would like to say a thank you to all who responded to my post.
Suffolkman
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
