Drill & tap, fuggedabout it. I would do straight threads, 5/16x24, loctite it, and stake a set screw in it.
Bob, the first link would really put some pressure on the hole, it's .020 - .030" larger diameter; the second one is really clever but needs a shoulder.
A light touch with a drill bit would put a shoulder in #2.
Anyway, here is the quick and dirty solution - dip a 1/4" steel pop rivet of appropriate length in anaerobic fluid (brown Loctite) and go for it.
