1998 F 150 electric seat bracket and seat swap from a expedition. ?
My 1998 Ford F150 can I use the whole seat bracket from an electric powered Expedition from a 1998 my bracket goes up and down but it doesn't go back and forth the sure seems like the motor is all one unit .
Or can I or can I use the whole seat and bracket from a 1998 Ford Expedition that's non electric or electric ?
Are you saying your seat doesn't have the option to adjust back and forth, or that it does and it just doesn't work? If it's the latter, have you attempted to diagnose it? It could be a simple issue like wiring that's been damaged and just needs to be repaired.
Otherwise, since I'm terrible at locating part numbers, the 2 things you'd need to make sure of are that the bolt holes match and the connectors are the same style. A local salvage yard should be able to tell you if they'll match up - most of them use software that allows them to look up which parts will interchange between years/models.
MikeTx354
1997-2006 Expedition & Navigator
05-22-2008 07:22 PM
