295/70R18, 3.73's, 2017+. How much change mpg/power?
Actually I'm wanting a wider footprint for all the off-road situations my truck gets used in. I'm aware that it will change the final ratio some. My question was how much mileage difference (numbers) and how noticeable is the difference in shifting and power delivery. If its fractional and barely noticeable it's worth it to me for the gained traction. If its more than that then I'm not sure. So for people who have actually done this and have data to assist me feel free to chime in.
I have 295/60/20's nitro terra grapplers with 3.73 gears on my 2011. i average a best of 18.6-7l/100k to a worst of 19.4l/100km. Empty or towing. My truck is decatted with one resonator also removed and dyno tuned for economy and towing. Sixth to fifth downshifts are kind of annoying under 100km/hr and over they're not an issue to me. I drive fast and heavy footed. Hit 160km/hr + a couple of times earlier today. I'd like to have lower gears I think. But in tow tune unladen it's hard to keep traction from the line as it is.
Attachment 261731
I just replaced my 17" onion peels with a set of 285/70/18 ridge grapplers. Lost a little umpf but at least I won't get stuck on wet grass anymore. I'm sure loose around 2-3 mpg around town, I'm at 15 now so no big deal there.
That said, I love the look of my 17" steelies like you used to have. Any particular reason you didn't just go with 285/70/17? Just mainly for the nicer wheel or what? Also, I have noticed that 285 or 295 is the largest you can go on tires with the 17" wheels as they are only 7.5" wide. I wouldn't want to go much larger than that even with 18x8 wheels, but has anyone had any bad experiences running a 285/295 tire on the minimum 7.5" wide wheel?
What wheels are those and where did you get them? I think they look like an older model year Ford factory wheel, but I'm not sure. Those are exactly something I'm interested in, not sure if I can stomach seeing another black wheel on a pickup without getting sick.
