Metal in the oil filter, no start. - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 09-07-2018, 11:33 AM
navistarnut's Avatar
navistarnut
navistarnut is offline
navistarnut has a great reputation on FTE.navistarnut has a great reputation on FTE.navistarnut has a great reputation on FTE.navistarnut has a great reputation on FTE.navistarnut has a great reputation on FTE.
I'm guessing the FICM L and P readings are so awful since it's during cranking?
If so, keep those batteries up do avoid further damage whilst cranking to diagnose,or you are at risk for more issues in that dept
Old 09-07-2018, 12:06 PM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
TooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud ofTooManyToys. has much to be proud of
I would really be nervous about the amount of metal on that filter if it was my motor. While the filter has a good micron rating, there’s also a 20psi differential valve. Oil pressure is pretty high when cold due to viscosity, and like most motors, for me there’s no reason to believe under cold start conditions that the bypass valve doesn’t open and circulate unfiltered oil.
Yes, the regulator have have stuck more open during a cold start, but I can see where a high contamination of oil pulled up from the pan could jam the regulator. I’d pull the regulator and see if it’s contaminated to start.
Old 09-14-2018, 04:11 PM
Nitro-Burner's Avatar
Nitro-Burner
Nitro-Burner is offline
Nitro-Burner is starting off with a positive reputation.
Itís looking more like a lifter came apart, hereís what the oil generator looks likes.
Old 09-14-2018, 04:52 PM
navistarnut
Oh boy......yeah those look like needle bearings for sure.
Hate to say it but it's time for a tear down
Old 09-14-2018, 05:32 PM
bismic's Avatar
bismic
bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
oil pickup tube
It is a shame that the oil suction tube in the pan doesn't have a finer screen. I assume the needle bearings fit through the screen lengthwise instead of tearing or deforming the screen.
That said, I suppose that if they did make the screen much finer, you might "suck in" the screen on cold mornings since thick/viscous oil can result in a lot of resistance to flow.
There was a recent thread on PSN that discussed the possibility of a tip of an injector hold-down bit getting through the suction screen. I guess the metal in the bit was defective and the tip cracked and fell into the head. The OP fortunately found it on the windage tray, but the discussion was interesting.
A diesel mechanic on that forum took the position that it absolutely couldn't pass through the suction tube screen, but obviously needle bearings can and so can injector spring clips. He also took the position that the screen is strong enough that it wouldn't get "torn".
I wonder if anyone has a dimension for the screen openings on this oil suction tube?
Just to relate a fear of mine, my son dropped a tappet from the mechanical fuel pump of a 7.3L into his engine. We rocked the front of the truck and I heard it drop t the pan. Lots of people said it couldn't pass through the oil pickup screen. That said, I put rare earth magnets on the pan anyway, and when I did, I heard the tappet move to the magnet (so I know it was in the pan and that the magnet had a hold on it). Haven't had any issue and it was a few years ago.
Then I came across this pic and thread:
https://cimg1.ibsrv.net/gimg/www.for...d68c763136.jpg
https://www.powerstroke.org/forum/94...ckup-tube.html
I guess it is possible to tear the screen!!
Ever since this experience w/ the 7.3L, I installed magnets on my oil pan for this very reason. Who knows if the magnets could grab hold before the needle bearings got "sucked up", but it makes me feel better anyway.
Old 09-14-2018, 07:09 PM
TooManyToys.
Sometimes there's an advantage of taking a god awful time to work through a motor with only the pistons, rings and con rods left in the block.
The unmodified version.
And I already have some rare earth magnets purchased to install within the motor at certain points. Ya know, if a valve cover screw and fit under an oil cooler ......
I was afraid to be the one to say where this thread was going, but there was just too much metal in the filter.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
