'49 F1 vapor lock
'49 F1 vapor lock
I was picking up parts yesterday in my '49, there was a bridge repair I got caught in an slow movement for 30 minutes combined with 95F air temp caused the truck to vapor lock. Temp gauge went between 3/4-H.
Are there any easy fixes for vapor locking fuel? My truck doesn't have the cooling fan shroud.
Here's the link to the thread Bill was referencing;
https://www.ford-trucks.com/forums/1...-remedies.html
Also please tell us about your engine and fuel system if it's non stock. A fan shroud will help. In city traffic, it's almost required in my opinion. And if you haven't already, try a non Ethanol blend.
The '49 is stock, when I bought the fan shroud wasn't included. I also own an '48 F5 & '52 F5 and they both have the shroud. I live in OH, so 10% ethanol is required unless you go to a marina. I don't often drive in traffic, I have never experienced vapor lock in this truck. I also have the stock 160F thermostats installed, when i bought it the engine really ran warm and after a little digging I found that someone had 195F thermostats in it but it did come from MN.
Thanks for the replies, I found the problem to be a partially clogged fuel line. The problem would manifest in hot weather.
I've always known my fuel tank has needed replaced, when I bought the truck it was probably 80% restored and evidently had been sitting for ???????years. I removed fuel tank and cleaned, then installed a suction side filter ahead of the fuel pump. Finally over the last month I was seeing less rust in the clear bowl of the suction Racor filter and thought I must finally have the tank cleaned up. Once again I was wrong as I decided to disconnect the fuel line and give it a shot of air from air compressor, problem solved.
My original thinking was I would hold off replacing the fuel tank until it started leaking. Later today I am going to take my mechanics magnet and see what rust I can remove through the fuel fill.
For a couple hundred bucks, is it really worth messing with and being stranded again? That's about the cost of a tow bill. How much time and money do you already have invested and still not fixed the issue? My 2c. Gas Tanks | 1948-52 F1 - F2 1953-56 F100 - F250 | LMC Truck
aj88V
05-30-2015 02:17 PM
1965f100factory4x4
03-19-2010 12:28 AM
dakonthemountain
13
07-22-2005 06:22 PM
