Redoing a 1979 F-100 Best Answers would help - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > General > Projects
Reload this Page >
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 08-26-2018, 09:38 PM
Ron Parsons
Ron Parsons is offline
Ron Parsons is starting off with a positive reputation.
I have always wanted to rebuild my old truck. I had a 1979 F-100 new in 1979, well I have found a truck that could very well be the old blue truck, I had. I want a 302 but this short bed 6th gen F series, but his has a straight 6. Drums all around would need to be changed as inter needs complete rework. Great look now so only window rubber and clear coat. AC missing under hood but rest just need rework. So should I do it for under $10,000 as a sometime used truck? What should I look for problems y'all have run into.
Old 02-02-2019, 07:22 PM
jade79
jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
If it's a 79 it should already have disc brakes on the front, think they came standard starting in 73? Check the front cab mounts and inside the rear fender lip for rust which are common problems with these trucks. A 302 swap shouldn't be much of a problem. You will need different/shorter frame perches. The 302 and 300 straight six share the same bellhousing bolt pattern so the trans should bolt right up. Based on what you've described 10 grand should be more that enough to get what you want done.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
