how fast should lube oil pressure rise? - lpop concerns after turbo failure
An air test can fool you since air is a hell of a lot thinner than oil, but looking at the air test I'd say that gauge has a restrictor. If it didn't I'd expect it to jump much more quickly. Do you remember if when you turned the motor off if the needle came down slowly, about the speed it would raise after start-up, or did it drop like it did in the air test? If slow, as I'm guessing, it's the gauge and there's probably nothing wrong with your motor. Also remember that the length of hose to the engine will also slow the response and in the air test you're blasting straight to the gauge.
No clue why the turbo went. I'm just looking to help keep you from possibly undergoing a big un-needed repair. So no answer on the gauge drop speed? That would pretty much tell the tale.
Normally when you start an engine the pressure rises increasingly faster towards the peak pressure and should take a second or two. When you turn it off it should do the same towards 0. If your pressure dropped at about the same rate that it rose it means that there's a restriction in the gauge. If it rises slowly at start up and drops quickly at shut down then there's a pump or engine problem.
Here's my .02 on the scratch on the front cover. Put the Melling in there and see what you get for pressure build time, If you're happy done....if not, then what are you out by putting it in? A little time? I'd much rather waste the time on the oil pump install than waste the time pulling the motor, changing the cover, and finding out that the pressure build time didn't change.
You had a piece of debris that made it through the oil pickup screen. Is there more debris of that size in the pan? Good question.
The scratch in the cover won't damage the new pump. For one it's an indentation, not a raised surface, and it's much softer than the pump. The only issue with that scratch is that it could allow for a small loss of flow/pressure since it won't seal as well, but I can't imagine it would be a measurable loss.
I get it, I was hoping you remembered what it did. If you pull the hose off the gauge and look into it you might get the answer. Most of them just use a little pressed in piece with a tiny hole, if you don't see that then it's probably not a restricted gauge, but it could have something further in where you don't see it. It doesn't much matter now, but if you get the same slow rise when the engine's back together do verify that it's not just the gauge or hose causing it. Hoping for you that that's all it was, I have high hopes that it is and your problem will be solved. Don't drop the new pump
#29
