Door code
Old Aug 25, 2018 | 09:08 PM
Eiland29's Avatar
Eiland29
Door code
I purchased my F350 from out of town. They delivered it. When i looked in the manual for the code it wasnt in there. I called and said they didnt even have it in there books. But i could bring it to them and they would scan it for free to tell me what it is. Well dont really want to spend a day driving and waiting to get this done. They did say local Ford would do it but charge me 100.00 any advice on any other way to find it?
Old Aug 25, 2018 | 09:13 PM
12Farmer's Avatar
12Farmer
My SecuriCode was printed on a credit card sized piece of plastic in the glove box as I recall. Yours was not in there?
Old Aug 25, 2018 | 09:22 PM
Eiland29's Avatar
Eiland29
No it wasn't. I looked through everything multiple times
Old Aug 25, 2018 | 09:24 PM
h20camper's Avatar
h20camper
Try this routine. It worked for me.
Using two different keys and cycling to the ON position for ~4 seconds with each key displayed my code on the IPC
Old Aug 25, 2018 | 09:37 PM
stangtime's Avatar
stangtime
The dealer had trouble locating my card (I found it once I got home), but they said it can be looked up in the system. Just give the dealer a call on Monday.
Old Aug 25, 2018 | 09:38 PM
Eiland29's Avatar
Eiland29
ipc? Whats that?
Old Aug 25, 2018 | 09:40 PM
h20camper's Avatar
h20camper
Instrument Panel Cluster
Eiland29's Avatar
Eiland29
They said they had to hook it up to the computer.
Old Aug 25, 2018 | 10:02 PM
stangtime's Avatar
stangtime
That's strange, mine said they could do it without me coming in. I found my card stashed in the compartment above my glove box.
Old Aug 25, 2018 | 10:13 PM
PentaPop's Avatar
PentaPop
Was your owners manual still wrapped in plastic when you got it? The card is always visible thru the clear plastic. If it wasn’t in there then Ford owes you one, and not for $100! On the other hand, if it wasn’t wrapped in plastic that means someone at the dealer opened it and lost the card in which case they owe you a new one, and not in exchange for an all day drive. If you’ve flipped thru all the pages of books and pamphlets in there and any secret pockets in the black bag and checked both glove boxes and under the seats and above the visors with no luck then I’d be raising some hell with the selling dealer.
Old Aug 25, 2018 | 10:24 PM
donjamer's Avatar
donjamer
Check this out... Especially method 3..
Not sure if it works, but can't hurt..
https://www.wikihow.com/Find-the-5-D...ry-Mountaineer
I had an 88 Lincoln that had stickers with the code in various places like the trunk..
Might want to look for one of those
Just found this video also
Old Aug 25, 2018 | 11:46 PM
logear's Avatar
logear
Did you check in the hidden area under the left cup holder? Slide left cup holder to the right, lift out removable tray then lift out bottom, look for little tab on right to help lift out.
You will see a key shape on the bottom area. Hopefully you will see your security code card first.
Old Aug 26, 2018 | 07:42 AM
h20camper's Avatar
h20camper
As mentioned in post #4 and displayed in this video starting at around 1 minute into it.
https://youtu.be/s0t-OvVuqUQ
Old Aug 26, 2018 | 11:27 AM
Eiland29's Avatar
Eiland29
This worked thanks everyone.
Old Aug 26, 2018 | 11:55 AM
fmuguira's Avatar
fmuguira
How many digits are in the code? Dealer set mine up for me and I know basic numbers used with can't remember if we used one or two zeros before the sequence...? I know, I m dense! Hey I m old and retired too!
Thx for any help
