How offten do you balance, rotate and align?
I rotate every oil change at 5k, balance every 10k and get an alignment x2 a year. Currently at 40k on my 325/65/18 duratracs with plenty of life left on these primarily Florida run snow tires. Some people have told me they will wear faster with the heat but I think they are the best 35 inch tire for my setup. Thinking of getting the balance done at 5k instead of 10 but idk if that’s necessary and there are ZERO buckzooka rounds remaining for the centramatics in advance lol. What are your service intervals for your tires?
Rotate when I think they need it after wearing.
Balance, has been when they are rotated, but will probably never balance again once I get Centramatic rings.
Alignment, once right after I bought the truck 4.5 years ago. If I notice the alignment out, I will have it redone.
About 30K miles on a set of Cooper ST MAXX and they have 40-60% life left.
Since I do have a plow now I'm considering going with Blizzacks on the nose this fall. While he Coopers have a nice, deep aggressive tread, which does do well in grass I don't think that they have the right combination of rubber compounds, tread and siping for the snow. I found them slipping a bit last winter when I don't think they should have been.
I have first-hand experience with both Hancooks IPIKE, Michelin latitude-X-ICE and Dunlop Winter Maxx. The Hancook’s have a little bigger voids for snow, and do very well on ice. The Michelin‘s are tighter tread design and really shine on heavy ice and also do surprisingly well on snow too. Both of these tires maintain their traction properties throughout the life of the tire. The Dunlop’s came on wheels I bought for my Subaru. I had never run these tires and on the surface seemed geared towards ice with very small voids, I wasn’t impressed. However, after running them for 2 seasons they have surprised the hell out of me! On slick ice they hook up as soon as The Subaru’s AWD kicks in, absolutely no Squirrley behavior. I’ve tried to get the car stuck in deep snow and the claw right through it. I would definitely consider them again for the Subaru.
Regarding the OP’S question. Honestly I never balanced the tires enough. Now that I have the Centramatic balancers hopefully that is taken care of for the life of the tires. I typically rotate with every oil change.
Every 10,000 miles I always purchase the "Lifetime Alignment", whenever I add to the stable. Tires Plus/Firestone include lifetime balance/rotation with a set-of-four purchase. The only vehicle I do my own LOF is the 7.3 all others go to the dealer while under warranty and then to Tires Plus after warranty.
We generally keep our vehicles at least 8-12 years or 200,000 miles (excluding the Excursion).
1) Balance for a vibration.
2) Rotate when I change a pair of tires (used to be every 2 years). I might need to revisit that, though, since that schedule should shift out to approximately every 4-5 years with my currently reduced driving distances.
3) I'll align when I get new tires or have to do suspension work (unless something goes wonky on me).
4) I fill with nitrogen and very rarely ever have to make a pressure adjustment (I also have free nitrogen top-offs at my tire supplier).
5) I watch the dusting "footprint" on the tread of each tire at every fill-up (once monthly), and I'll adjust my level of above actions if I see something odd taking place with one or more tires.
Long answer, Quality is rarely cheap, I’ve been running them on my Jeep with 35’s MT’s for 7 years. I’ve never balanced the tires and experience zero vibrations and smooth, even wear. It was my experience with my Jeep that convinced me to put them on my Dually. My experience with my truck has been 100% positive. I would buy them again in a heartbeat! The part numbers are in my original thread if decide to go that direction. IMO, buy them directly from Centramatic so you get the real thing.
EDIT- here’s the link:https://www.ford-trucks.com/forums/1...installed.html
Short answer-YES!
stkelly
07-18-2011 04:40 PM
berry1234
15
08-19-2009 03:58 PM
