Moog, tie rods, and other suspension stuff - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 10-17-2018, 02:39 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
sky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputation
Slightly off topic, but we put some new moog parts on a company dodge pickup recently , and the packaging was all marked made in the USA.
Old 10-24-2018, 08:05 PM
Fuzzpuss
Fuzzpuss is offline
Fuzzpuss is starting off with a positive reputation.
Not off topic at all. Thanks for the input.
I wish others would chime-in about other suspension parts brands they've used and their experiences.
Hey moderators, can I change the title of this thread to maybe something like "Moog, tie rods, and other suspension parts and brands you've used"?
Old 10-24-2018, 08:34 PM
Yahiko's Avatar
Yahiko
Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Edit the first post and go into the advanced option and then you will have access to the topic if the post is not too old.
08-23-2018 so you should be able to do that.
Old 10-25-2018, 08:09 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Originally Posted by Motohead911 View Post
I just did my drag link and tie rods ends with Moog parts, and they were all made in the US per the boxes. FYI I got them from Rockauto.
The boxes were made in the US.
Old 03-13-2019, 10:10 AM
coolfeet's Avatar
coolfeet
coolfeet is offline
coolfeet is gaining momentum as a positive member of FTE.
I checked the tie rods and I can feel movement when I grab the center link bar like a pull-up bar and twist them. Not sure if this is normal. I do not hear any clunks while driving. Steering feels tight. I replaced upper and lower ball joints 45k ago. I don't want to replace if this movement is acceptable.
Old 03-15-2019, 06:03 PM
mastersativa
mastersativa is offline
mastersativa is starting off with a positive reputation.
69cj is right, the boxes are made in the usa, the parts are not. Our rep from our parts supplier told us this. With that being said, the problem solver moog is still our "premium" replacement part we install. We use their quicksilver brand as our economy part, still made by moog. Now, are you sure your sway bar bushings are ok? Just a little deflection can add up to a big clunk. But, that doesn't explain why the noise would go away after greasing the tie rod. Is this noise consistent? Will it happen every time you drive it? Is so you can try removing the sway bar completely and seeing if the noise goes away. Another thing I can suggest is looking at your frame just in front of the steering box, and the same spot on the passenger side. Mine cracked there on both sides, just a thought.
Old 03-15-2019, 08:52 PM
Yahiko's Avatar
Yahiko
I have new bushings here for the front sway bar. The reason is I was getting this clunk every now and then. I
happened to be under the front and looked up and found one of the bushings was missing the lip that keeps it in
place. I Just so I could wait for the parts I pushed it back to where is should be. I then ordered the new bushings.
They showed up and I have not had a clunk in more than a year and the new bushings are still in the box they
cam in. I really should put them in.
Old 03-23-2019, 06:40 PM
Monster-4's Avatar
Monster-4
Monster-4 is offline
Who? Me?
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Opps wrong thread
Old 03-23-2019, 07:41 PM
Fuzzpuss
Fuzzpuss is offline
If you're addressing me, the sway bar bushings are good. And I think the relationship between the clunk and greasing of the tie rod was a coincidence. The creaking during right turns has been consistent since I started this thread, but it had been months since I heard the clunk, until last week when I drove down a curb at low speed and again it sounded like a hammer hit the floor by the passenger's feet. I pulled the tie rod end links again and the ball joints are tight, though the passenger side ones were oozing grease. I theorized it was due to more frame movement on that side because of failing cab mount bushings. And I suppose the Helwig sway bar can add to the movement if things aren't tight all around. So I picked-up some Energy Suspension mounts yesterday and installed. And just like everyone says, those front ones are a real biotch. I haven't driven it yet so I don't know if it made a difference. I'll be starting a new thread about the experience with several pics along the way.
Old 03-23-2019, 07:44 PM
Fuzzpuss
Fuzzpuss is offline
I would only worry if its really easy to twist, as in almost dropping back down under its own weight right after you push it up.
Old 03-23-2019, 07:48 PM
Fuzzpuss
Fuzzpuss is offline
I just re-read this post. What a crack-up! You're like the charter member of the national procrastinators club.
Old 03-23-2019, 08:27 PM
Monster-4's Avatar
Monster-4
Who? Me?
Sorry I bumped the wrong thread
  #28
Old 03-23-2019, 10:34 PM
Yahiko's Avatar
Yahiko
Sure am.
I think I would give it up if I ever felt like doing the giving but it way less work to just let that award sit on the shel collecting dust.
At least I did get the new compressor mostly installed. Still need to do the safeties and put the covers on the wiring/
  #29
Old 03-23-2019, 10:40 PM
coolfeet's Avatar
coolfeet
coolfeet is offline
itís still tight. I greased them and will drive another year or two
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
