Caliper Piston & Pad Clip Size, 2011
I'm chasing my tail on a simple brake job.
Build date is Jan 11, but I swear I have small clips, cause the "wrong" set I brought home first time were larger.
Now I have brake wobble {rotors turned} & it looks like I have possibly ANOTHER incorrect set of pads (stock # comes back as "not for your vehicle" on their [O'reily] site )
I have the original pads for measurement, it looks like a 40mm witness mark on them.
Right now. I can only find 1 set on line that even MENTIONS that there is a "large clip" size.
Does any body have firm numbers on actual measurements or info?
I'm looking at a Power Stop Rotor & pad kit # KOE5571 , but I can't get through their help line to ask.
At any rate, took receipts & box back and had a discussion with counter person @ O's.
He/we did a bunch of computer cross referencing.
Indeed I had gone home originally with "big clip" pads & the ones I eventually installed were small clip alternate part # pads, but the number was indeed good.
Can't say why they are there, since all documentation I CAN locate says that production didn't change over to small clips until 4/11.
I've got the Powerstop daily driver pad & rotor kit on order from Rock.
Hope this helps any '11 owner who has the same questions in the future.
