Which Bilsteins? - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Which Bilsteins?
Old 08-23-2018, 09:20 AM
Nattex18's Avatar
Nattex18
Nattex18 is offline
Nattex18 is starting off with a positive reputation.
Which Bilsteins?
I have a 2018 F250 leveled with 35" tires. I put the Bilstein 5100s on the front which have proven to be a definite improvement over stock. My problem is I can't confirm that Bilstein makes replacements for the rear. Their website does not show anything for the rears. I know I have seen posts with people having replaced both front and rear. Can anybody give me a part number for these? Thanks
Old 08-23-2018, 10:01 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
"><img src=" /> ">
CDN$ 126.05
"><img src=" /> ">
CDN$ 144.05
here is what I found on Amazon . CA. If the front part matches yours, then the rear is the correct on. I think this is for stock, not necessarily a lift.
Old 08-23-2018, 10:21 AM
Nattex18's Avatar
Nattex18
Nattex18 is offline
Thanks. But the Bilstein part number for the fronts was 24-274951. So I'm still not sure. lol
Old 08-23-2018, 11:37 AM
Norris McCarty
Norris McCarty is offline
Norris McCarty is starting off with a positive reputation.
Use the rears that fit a 2016......then change the lower bushing to one that fits the 9/16" mounting stud or just drill the existing hole in the shock out to 9/16". Drill slow with oil so the bushing doesn't get too hot and it'll work great.
Old 08-23-2018, 02:09 PM
rfbrain
rfbrain is offline
rfbrain is starting off with a positive reputation.
Here are the part numbers for the 9/16" Sleeves and Bushings
9/16" Sleeve BSN-195452
3/4" Bushing BSN-2202G
Just press old ones out and replace.
Old 08-23-2018, 11:25 PM
brandon4
brandon4 is offline
brandon4 is gaining momentum as a positive member of FTE.brandon4 is gaining momentum as a positive member of FTE.
Shox.com has rears. I just got them on my truck.
Old 08-24-2018, 12:01 PM
Frac Master
Frac Master is offline
Frac Master is starting off with a positive reputation.
Last time I checked, Bilstein had not released the rear shocks or a steering stabilizer for the 2017+ Super Duty. Ive been running the front shocks for a while now and they made a huge difference. I've been holding out and waiting for the rear shocks and a steering stabilizer but not sure how much longer I can wait.
Old 08-25-2018, 10:02 AM
disker
disker is offline
disker is starting off with a positive reputation.
Are the 5100's just for a lifted truck? Or can they be used on a stock truck (on the front). I called 4wheel drive .com and the guy told me the 5100's were just for lifted trucks---- but I thought guys had been using them on stock rigs too. I have a stock truck and want to get the Bilsteins on it. He told me to go with the 4600's.
Old 08-26-2018, 04:04 PM
bansheemike
bansheemike is offline
bansheemike is starting off with a positive reputation.
I bought these for my 2018 F250 FX4 and they were about 4 inches shorter extended than my stockers.
Not putting them on until further notice.
Old 08-26-2018, 07:08 PM
Norris McCarty
I used Bilstein #s 24-186025 and 24-186018.... they fit and the ride is very good.
Old 08-26-2018, 09:28 PM
disker
disker is offline
Is your truck stock or lifted? Trying to find the part number for the front for a stock truck (for the 5100's)
Old 08-27-2018, 07:24 AM
Norris McCarty
Stock, not lifted.
Old 08-27-2018, 09:26 AM
bansheemike
Stock FX4 rears.
I'm going to pull on of the rear shocks off again and compare it to the Bilstein's before I send them back.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
