2017 F350 duel rear wheel valve stem eatention - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 08-23-2018, 08:15 AM
rwtdct's Avatar
rwtdct
rwtdct is offline
rwtdct is starting off with a positive reputation.
I have a buddy that says he cant find a valve stem extension for his inner dual wheel that works, what is people here using? How did you fix the problem?
Old 08-29-2018, 08:28 AM
rwtdct's Avatar
rwtdct
rwtdct is offline
I guess no one else has had this issue.
Old 08-29-2018, 10:52 AM
N2dunz's Avatar
N2dunz
N2dunz is offline
N2dunz is gaining momentum as a positive member of FTE.
Extension to do what?
I bought an air chuck extension for adding air.
I bought a extended air pressure gauge.
Got both at Auto Zone.
No big deal.
Old 08-29-2018, 03:44 PM
bobv60
bobv60 is offline
bobv60 has a very good reputation on FTE.bobv60 has a very good reputation on FTE.bobv60 has a very good reputation on FTE.
Where has he looked and how big is he looking for? Both of my last ford duallys had about a 1" long extention. As long as the wheels where clocked correctly when installed, there was no problems getting a air chuck on them
Old 08-30-2018, 10:15 AM
rwtdct's Avatar
rwtdct
rwtdct is offline
Going by what my buddy stated, he take his truck to the dealer they have to take the wheel off to add air. To me that would be a big deal.
If I remember right, he said he has tried a extended air chuck but the angle of the metal valve stem you cant get a metal extended chuck on it, and a extended hosed chuck (flexible) you cant get your fingers in there to hold it on the valve stem.
Old 08-30-2018, 11:00 AM
N2dunz's Avatar
N2dunz
N2dunz is offline
Someone is an idiot and put the wheels on wrong.
You have to line up the valves.
I had to correct the 16 year old kids at Discount about that one time.
If the dealer is doing that, I would find another dealer.
Old 09-05-2018, 09:37 AM
robeyster
robeyster is offline
robeyster is starting off with a positive reputation.
Milton S-690-12 Twelve Inch 1/4" FNPT Dual Head Air Chuck. This is the air chuck I use and works great for filling inner tire.
Old 09-05-2018, 09:47 AM
rwtdct's Avatar
rwtdct
rwtdct is offline
Thank you robeyster for the info. I will pass this on to my buddy.
Old 09-05-2018, 01:24 PM
Bigdon68
Bigdon68 is offline
Bigdon68 is gaining momentum as a positive member of FTE.Bigdon68 is gaining momentum as a positive member of FTE.
Valve stem extensions, https://www.bing.com/shop?q=tst+tire...BC0B798124A4FD
I have the 180 degree extensions on my rear duals -- for the TST Tire sensors.
bigdon68
Old 09-05-2018, 02:33 PM
rwtdct's Avatar
rwtdct
rwtdct is offline
bigdon68
Thank you I will also pass this along.
Old 01-18-2019, 08:36 AM
Glenn K
Glenn K is offline
Glenn K is starting off with a positive reputation.
Is there a technical reason the air valves have to be back to back?
Old 01-18-2019, 01:06 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
this is what I used..
Amazon Amazon
also my install on my 2012 dually.. still have to redo on my 18
https://www.ford-trucks.com/forums/s...1&postcount=46
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
