Sponsored by: Real Truck
P0705 - transmission range sensor
Old Aug 22, 2018 | 10:37 PM
Mac Daddy's Avatar
Mac Daddy
Woke up this morning and lit up my 2001 F250 V10 and was greeted with a check engine light and code P0705 - transmission range sensor. My guess is it's time to flush the fluid...she's got 225k miles...and we routinely push 25 to 28k total gvwr between the truck and a 5 ton gravel trailer. Might also be continuing issues from the fire we had when the rear main failed a year or so ago. Chared the wiring harness a bit.
I cleared the code and it did not return...
Thoughts?
Old Aug 23, 2018 | 06:02 AM
projectSHO89's Avatar
projectSHO89
A P0705 has nothing to do with the fluid. It's an electrical circuit fault. Could be the DTR switch, its connector, the wiring, or the PCM.
skinny29286
Dec 16, 2013 08:43 PM
simsbud
Jul 3, 2011 05:49 PM
SandR
1997 - 2003 F150
Feb 5, 2011 09:17 AM
kentpsmith
1997 - 2003 F150
Jul 22, 2003 12:12 AM
