Getting the “Green Mill” running again 1974 F250
#31
i installed the rebuilt Holley 4 barrel carb yesterday. I took your advice and ran some gas by cranking the engine. This gas looks and smells bad! I’m planning to siphon out as much gas as I can tomorrow and then put in some new gas. I installed the new stock metal gas filter but I’m going to add another clear one so I can watch it and change if necessary
i really don’t want to drop the tank and clean/recondition if I don’t have to. What do you think?
After being lazy with mine, I recently had to help a friend drop a 3/4 full tank to change a fuel pump and we found a ton of junk in his tank. And it was a 96 and had only sat for a few months. The process wasn't as hard as I made it out to be and it worked out way better in the end because the pump wasn't the issue. Knowing the tank was clean and had 100% good, fresh gas eliminated a lot on the troubleshooting later.
#32
#34
#35
#36
#37
#38
The shift collar broken seems most likely.
Shift collar videos (3 part video for a Bronco- very similar to F-series):
The shift linkage could be disconnected at column end or transmission. This should be easy enough to spot visually. A badly slipping tranny would be the only other likely option. Check the fluid level and make sure the fluid is not burned. Other less likely options could be a disconnected driveline, stripped rear yoke, or differential issues.
#40
#41
#42
Well if the linkage is moving at the transmission, you are correct- the collar is good and linkage is connected. When going through the gears, can you hear it even try to engage and does the driveline at all? Speaking of, since you were under the truck I would think you would have seen a disconnected driveline, but it never hurts to ask. So far, it seems to me the next most likely suspect is the transmission. Did you check the transmission fluid level and smell it to see if it smells burnt?
#43
Did you check the oil level on the transmission? Maybe the vacuum modulator has a hole in it sucking ATF into the engine making it smoke...Or your smoke could be bad valve guide seals.
#44
Transmission
I put 4 quarts of the F type trans fluid in. Now it’s like she is wanting to go in gear. Then the rain started so I’ll work on it more tomorrow
iI am trying to get the engine to run a little smoother so I started checking the vacuum lines. I took off the plug on one of the unused ports on the manifold and she started running great! Why would it do this? I know I can’t leave it open.
#45
