The Best Aftermarket Headligths for the new F150 trucks - New Release!
Stunning quad LED optics with bright diamond white LED bulbs and beautiful sequential DRL bar are the key elements of this model. They produce a well-defined beam pattern with a great amount of width, intensity, and a proper distribution of light no matter where your truck is headed to. These headlights are designed for 2018 + Ford F-150 models and now they are available for Pre-Order at CARiD.
Morimoto® - XB™ Black Sequential DRL Bar Projector LED Headlights
https://www.carid.com/2018-ford-f-15...212462268.html
*Watch the video on our site to see the lights in action!
Features:
- Good for 2018 + Ford F-150 models
- Include 2 Headlights and XB LED Driver Modules
- Bulb type: Osram Ostar LED for Headlights and DRL
- Color temperature: 5500K (pure white)
- Color temperature (DRL): 5000K
- Raw lumens (per headlight): 2600
- Lens material: UV-coated polycarbonate
- Housing material: PPS plastic
- LED optics: Kuria Quad optics
- DOT, ECE, SAE, FMVSS compliance
- IP67 waterproof
- Connector: Ford multi-pin.
Morimoto™ | LED Fog Lights, HID Projectors, Bulbs — CARiD.com
https://www.carid.com/morimoto/
Estimated availability date is 10.01.2018
If you want your Ford to stand out and enhance the visibility at the same time - Morimoto XB™ Black Sequential DRL Bar Projector LED Headlights will be your best bet!
Hello everyone! We are back with the new video review on one of the most exciting and highly-anticipated releases for 2018 + Ford F150 – Morimoto XB™ Black Sequential DRL Bar Projector LED Headlights! If you want your Ford to have a set of headlights, that is truly different in terms of the looks and lighting performance, Morimoto LED headlights will be your best bet.
These headlights, designed specifically for 2018 Ford F150 and up models produce a well-defined beam pattern with a great amount of width, intensity, and a proper distribution of light. Their UV-coated polycarbonate lens is sure to resist the test of time. Plug-n-play installation and switchback combination of turn signals and DRL makes them the best possible option available for the new Ford F-150!
Watch our new video review to find out what are the main specifications of these headlights and how they can be installed. If any questions appear, contact me directly in PM or comments below.
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
11-14-2018 08:49 AM
Auxbeam Lighting
01-17-2017 03:20 AM
carid
01-04-2017 07:42 AM
carid
04-18-2016 09:44 AM
