Type AC condenser and location
When starting out cold driving I think it gets up to 180 degrees on gauge temp to fast and the fan set-up works good on at 210 off at 180 degrees but I think it is over working . I do not even use AC just got all hooked up not charged--- I am concerned AC condenser is taking to much rad area up-- MUST be another type condenser someone used--LOWER--LONGER or ? -- I can put dryer in on inner fender
Received 4,119 Likes
on
on
on
Does your water pump have a bypass, I also have a Vintage Air front runner in my panel ( 5.7 liter sbc) it didn't have a bypass because of the supplied pump . I had over heating problems until I made a bypass by tapping into my return heater hose to the intake manifold. When I used the bypass thermostat they provided I couldn't get the engine up to operating temperature below 55° air temperature..
on
on
The square corner on gaskets are visible like stated above-- to EXPLAIN myself --- I do not have over heating problems anymore heating fan sensor is working correct and cools it back down to 180 degrees NO problem -- I am saying with the Vintage Air condenser as they instructed is blocking a lot of air --- I just thought it went up to 180 degrees fast but then again I got to understand it is a NEW tight motor with 30 miles on it ---- the cooling problem is solved--
Just looking for other ideas on different type AC condenser-- such as a longer one and a narrow one to install at low part of radiator , then I will have 65 % of rad. open instead of 10% that Vintag Air engineered--- I am dealing with the Vice President of the Co on this problem --- Me and my Friend which is a Street Rod builder installed lots of VA equipment but never see a problem like this unit from the start
