Why Ford have such lame rear end gear ratios? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 08-20-2018, 09:58 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
sawtooth is gaining momentum as a positive member of FTE.
So Iíve reviewed a few reviews online plus watched several youtube videos on towing in extreme mountains and see the Powerstroke just doesnít cut the mustard as compared to Ram and Chevrolet. From what I can tell though Chevrolet and Ram offer a 3.73 and 4.10 rear end plus GM has the 7speed tranny. Ford has a 3.31 and 3.55 with a 6 speed. So why is Ford going with such high ratios? No wonder they canít compare pulling against 3/4 and 1ton trucks. Also, I wanted the 3.55 ratio in a F350 but just realized I must go with the camper package (stiffer springs) in order to get it. Totally donít understand....
Old 08-20-2018, 11:57 PM
bobv60
bobv60 is online now
bobv60 has a good reputation on FTE.bobv60 has a good reputation on FTE.
Dont know about GM but Ram in non Dually DIESEL is 3.42 ONLY. TO GET 373 OR 410 with a Diesel you must have a DRW.
Old 08-21-2018, 05:46 AM
lawnspecialties
lawnspecialties is offline
lawnspecialties is gaining momentum as a positive member of FTE.lawnspecialties is gaining momentum as a positive member of FTE.
My 2015 F350 SRW had the 3.55. It pulled my 18,000 lb. toy hauler like a champ.
Old 08-21-2018, 06:10 AM
cattaco
cattaco is offline
cattaco is starting off with a positive reputation.
GM is still only a 6 speed.
Old 08-21-2018, 07:01 AM
CO Wapiti's Avatar
CO Wapiti
CO Wapiti is offline
CO Wapiti is starting off with a positive reputation.
That’s a great question! I would lave loved to have a 3.73 and 4.10 option just to compensate for taller tires that a lot of us put on our trucks.
I think the 3.42 in the Ram is only if you get the high output Cummins and Aisin tranny (which is a hefty upgrade too $$). I’m guessing it’s to compensate for the different output ratio of the Aisin. I remember being disappointed while building a Ram too.
Old 08-21-2018, 07:20 AM
Beast2.0
Beast2.0 is offline
Beast2.0 is starting off with a positive reputation.
That's probably why they are able to pull a quicker time on their YouTube commercials. I bet they are not apples to apples equipped. My '18 F350 PSD Dually has 4.10's in it and it pulls great!
Old 08-21-2018, 07:21 AM
sawtooth's Avatar
sawtooth
sawtooth is offline
Originally Posted by CO Wapiti View Post
Thatís a great question! I would lave loved to have a 3.73 and 4.10 option just to compensate for taller tires that a lot of us put on our trucks.
I think the 3.42 in the Ram is only if you get the high output Cummins and Aisin tranny (which is a hefty upgrade too $$). Iím guessing itís to compensate for the different output ratio of the Aisin. I remember being disappointed while building a Ram too.
i think you are correct. I built a Ram without the Aisin tranny and all three ratio options were available. As another poster mentioned iím Going with one size larger tire on a 18Ē wheel so need a little lower gearing to keep everything the same. I will only buy a super duty just hate to so a GM whip us up those mountains. From personal experience the GM trucks just donít handle the weight like a super duty but would like to us have a more aggressive option if the buyer wants one. Iím probably going with the 3.55 in my new F350 but will have to change the front springs out if itís a little stiff on the local dirt roads. Just seems Ford shouldnít force us in a corner for something we donít need.
Old 08-21-2018, 07:22 AM
sawtooth's Avatar
sawtooth
sawtooth is offline
i think you are absolutely correct.
Old 08-21-2018, 07:32 AM
bigred460ci's Avatar
bigred460ci
bigred460ci is offline
bigred460ci is starting off with a positive reputation.
Change to what you want for a ratio. I changed my '79 to 4.10's, I ordered my 05 F350 with 3.73's changed them to 4.10's (should have gone with 4.30's). I now have a '18 F350 that I ordered with 3.55's, debating to go with 3.73's or 4.10's.
Old 08-21-2018, 07:40 AM
nick112288
nick112288 is offline
nick112288 is starting off with a positive reputation.
Ram is 3.43 UNLESS you get the dually. Then it is 3.43, 3.73, 4.10. Unless you get the manual, then the best you can get is 3.73.
Chevy is 3.73 no matter what.
Ford is 3.31 or 3.55 in SRW. 3.55 or 4.10 in dually. 4.30 only in F450
These are all diesel engines. Gas options are different
Old 08-21-2018, 07:42 AM
bitNine
bitNine is offline
bitNine is starting off with a positive reputation.
In the Ram you can only get the 3.73 and 4.10 gearing on DRW trucks w/Cummins.
Old 08-21-2018, 08:05 AM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
Those comparison videos are for entertainment and are not real tests. Those guys have no understanding of proper testing. There is way to much wrong with their methods to try and list here. Even if the tests were done properly you shouldn't base your buying decision on the results of a single test, on one specific climb, unless that particular climb is your primary use.
Old 08-21-2018, 08:17 AM
sawtooth's Avatar
sawtooth
sawtooth is offline
Originally Posted by Clubwagon View Post
Those comparison videos are for entertainment and are not real tests. Those guys have no understanding of proper testing. There is way to much wrong with their methods to try and list here. Even if the tests were done properly basing you shouldn't base your buying decision on the results of a single test, on one specific climb, unless that particular climb is your primary use.
itís more than just a single test there actually multiple reviews and even some people on this forum that Iíve noticed the same issue. My point is why does Ford not give someone the option for lower gearing if they want it. Many buyers plan to upsize tires thus raising the effective ratio. Not only does Ford not offer a 3.73 or 4.10 ratio but also forces you to take on other options there may not be desired. Basically they are saying take the 3.31 and like it. Just seems to me someone missed the boat on this at Ford. Either way Iím going to try the 3.55ís and worst case scenario is to spend even more money changing out the front springs.
Old 08-21-2018, 08:19 AM
Rtr2017!
Rtr2017! is offline
Rtr2017! is starting off with a positive reputation.
That’s why I love the 6.2 4.30 combo
Old 08-21-2018, 08:30 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a name known to allPaw's 150 Lariat is a name known to allPaw's 150 Lariat is a name known to allPaw's 150 Lariat is a name known to allPaw's 150 Lariat is a name known to allPaw's 150 Lariat is a name known to all
Buddy of mine has a '16 Ram 4x2 DRW with the Cummins and a 3.42 rear. I let him drive my truck and now he's thinking Ford...both of us pull camper's but he only pull's a 9K pound bumper pull.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
