tools and equipment you keep in your truck utility/flat/stepside bed?
I sometimes keep an older toolbox, ice cooler and gas can on my bed, and now want to put some larger service truck related equipment and am looking for ideas.
I just cleaned up an older 12 gallon air compressor with plans to mount on my flatbed, and am going to go look at 60's/70's Lincoln welder/generator for sale on Craigslist today.
What are some things you keep in your bed? Or some ideas for "Old Service Truck" ?
this is what I got to work with....
Received 4,132 Likes
on
I agree with John. A nice frame mounted polished aluminum diamond plate box would look great. A more spartan look would be a bolted down Knaack box on the bed, but I think it depends on how much and how high you'll be lifting the bed.
A very good looking truck, btw.
And the lighting police just noticed that you have an amber lens on your left rear marker light.
on
Yes. Always red at the rear, with the exception of amber turn signals and backup lights (vintage vehicles can use blue dots, varies by state). And I'm hoping the marker light attached to the taillight isn't a turn signal because it doesn't meet luminosity standards for a turn signal. An easy ticket for an informed LEO.
That air compressor cleaned up real nice. Usually air compressors are powered by gas engines on service trucks. I see that your welder is rated for 3,500 watts @ 115VAC, so that translates to around a 5 HP engine. What is the amp rating on the compressor motor, or have you already done the math on powering the compressor with the welder?
That's going to look sweet. Hope you have a nice rain cover for all of it.
DOT, NHTSA, and OSHA require the caps to be in place when the bottles are being transported (not in use). And technically, the compressor motor should be explosion proof being that close to the acetylene bottle. Maybe you could reverse the bottles? I really like your setup, but I want you to be safe.
https://www.law.cornell.edu/cfr/text/49/173.301
Do NOT use oil or grease on any of the threads. Use anhydrous lanolin or beeswax, or other non petroleum based lubricant.
And the oxy-acetylene bottles must be securely chained or strapped in such a way to prevent them from tipping.
I made these brackets to secure bottles and am looking for a deal on some of these safety/transportation caps...
also thanks for link and info about cylinders... I've been checking into and think I'll be "legal and safe" with caps pictures... I never considered the motor is too close to the acetylene cylinder, might swap locations to gain a few more inches.
