Ford Mexico tune help - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 08-19-2018, 08:11 AM
Wayne64SS's Avatar
Wayne64SS
Wayne64SS is offline
Wayne64SS is starting off with a positive reputation.
Has anyone on here flashed their truck with the factory ford mexico tune that allows you to remove the muffler? I'm just curious as to how that works... I have the tune file for hptuners and also hptuners. Do I need to buy credits for engine and trans or just engine? Do I need to do a segment swap or something to get it to match my vin? Thanks in advance.
Old 08-19-2018, 08:42 AM
1olddogtwo
1olddogtwo is offline
1olddogtwo is starting off with a positive reputation.
You need to continue doing some preliminary research 1st.
Sounds like this is your 1st diesel, and clearly you have a lot to learn, hint, there is no muffler on the 6.7.
Old 08-19-2018, 08:46 AM
Wayne64SS's Avatar
Wayne64SS
yea it's my first day. troll elsewhere please, or at least read between the lines before you post ****ing nonsense.
Old 08-19-2018, 12:45 PM
brandon4
brandon4 is offline
brandon4 is gaining momentum as a positive member of FTE.brandon4 is gaining momentum as a positive member of FTE.
We all knew you meant dpf. That would be awesome to get a Mexico tune. I've never thought about the fact they don't have emissions.
Old 08-19-2018, 12:54 PM
blueglide
blueglide is offline
blueglide is starting off with a positive reputation.
https://www.ford-trucks.com/forums/1549939-poor-mans-dpf-delete.html?
I thought from this earlier thread you couldn't do this without a tuner, etc. I don't know how to make this earlier link hot.
Old 08-19-2018, 01:17 PM
D3thM3tal's Avatar
D3thM3tal
D3thM3tal is offline
D3thM3tal is new and has a neutral reputation at this point.
The delete tunes are from MX - they don't have any DPF or DEF down there.
Old 08-19-2018, 01:25 PM
Wayne64SS's Avatar
Wayne64SS
hptuners is a tuner. It will require a flash i dont want any additional power or nothing just need to stop this regen horse****. Almost 3 times this tank im only through half a tank.
Old 08-19-2018, 01:31 PM
blueglide
I'm old and slow so there's that but what would be the advantage of using Mex tunes? Why not use your tuner and do a standard delete with tunes available in the states?? If you remove the dpf and use block off plates etc what is the advantage?
Old 08-19-2018, 01:38 PM
D3thM3tal's Avatar
D3thM3tal
That is where the tunes are derived from - that's all I'm saying.
Old 08-19-2018, 08:41 PM
UGA33's Avatar
UGA33
UGA33 is offline
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
Don't run an export calibration. It's garbage. All tunes before true custom tuning was available for the 2017+ Super Duty 6.7s were derived from the Ford export calibration. Truck actually felt weaker and it soot loaded the oil really bad.
If you are wanting to delete, just use a reputable tuner and be done with it.
Old 08-19-2018, 08:50 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
The export tunes are horrible! Don't use them, they are junk. You need to understand the rest of the world is okay with turbo lag, and odd short powerbands. The tunes also create more soot than necessary, get a real delete tune at stock calibration.
Old 08-20-2018, 06:29 AM
Wayne64SS's Avatar
Wayne64SS
I wanted to go this route mainly for warranty.
Old 08-20-2018, 07:19 AM
Wayne64SS's Avatar
Wayne64SS
also realistically with the mexico tune file and my stock file i can copy all the stock fueling tables over (all the mode 0 are out of regen)
Old 08-20-2018, 07:53 AM
UGA33's Avatar
UGA33
UGA33 is offline
Think Ford is gonna honor your warranty with an export calibration in the States?
Old 08-20-2018, 08:17 AM
Blwnsmoke
Blwnsmoke is online now
Blwnsmoke is gaining momentum as a positive member of FTE.Blwnsmoke is gaining momentum as a positive member of FTE.
Apparently lol.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
