4r100 no overdrive
Old 08-19-2018, 06:34 AM
jebdeam's Avatar
jebdeam
jebdeam is offline
4r100 no overdrive
01 excursion. 4r100, fresh rebuild, supposed to be a stage 5 with a monster torque converter. I put the tranny in, hooked everything up, it’s full of fluid, shifts fine in every gear but won’t shift into O/D. It will redline in 3rd but won’t shift out. Reverse will kinda shudder a little sometimes too, idk if that has anything to do with it. No programmer, all stock. O/D light flashing so hooked up a scanner, i don’t remember what the codes were exactly but it’s getting the command to shift into every gear, solenoids are on and off when they’re supposed to be. I’m just at a complete loss and I’d like some insight before I probably have to tear into it. Thanks guys!
Old 08-19-2018, 09:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
Without knowing what codes were set all I can tell you is that something is wrong.
Old 08-19-2018, 10:22 AM
jebdeam's Avatar
jebdeam
jebdeam is offline
solenoids were bad or something like that and mechanical problem is what the code numbers were
Old 08-19-2018, 02:11 PM
Mark Kovalsky
OK, then something is wrong, or something like that.
Old 08-19-2018, 02:14 PM
jebdeam's Avatar
jebdeam
jebdeam is offline
I’m glad this account is free cause I don’t think I could have figured that out on my own
Old 08-19-2018, 09:09 PM
Mark Kovalsky
If you won't provide the codes I certainly can't figure it out.
puller45
01-04-2016 08:05 PM
bandlgeorge
08-11-2015 11:11 AM
lllateralus
1997-2006 Expedition & Navigator
07-26-2010 03:36 PM
mdmjdm
34
05-02-2010 05:24 PM
jnye6625
02-26-2007 12:05 PM
Quick Reply: 4r100 no overdrive
