Oil filter change mess?
#46
Ok I just did my oil filter Motor Craft again punched the awl 5 inch’s all the way to handle.
In the center of filter let drain till no oil was coming out fill cap removed Dip stick removed started to unscrew oil filter running all over outside of filter.
From previous comments some how you need to open the bypass in filter.How do you get the bypass to stay open when changing the filter?
I have changed my oil five times same results no matter how many holes I have punched in filter a mess.
Thanks
Thanks
I change my oil hot and puch the awl in until it hits the handle about 1 to 1.5 inches from the edge of the filter and don't have a mess. I had a mess one time, which was the one time I changed the oil while it was cold. I also may have punched the hole more towards the center and didn't go deep enough.
#47
#48
#49
#50
#51
#53
#56
The people I've seen using them on a 2011 have swapped to the metal oil pan so they can install. It's only like $25-35 for the pan (I think) so you'd just have to make the effort.
#57
#58
Crack the filter, let it drain. Then remove the filter. you will still get about a quart of oil making a mess since the drain back valve stops it from draining.
I have never seen this much oil come out, above and beyond what the filter holds, of any engine except this one.
I punch a hole in the bottom straight up, let that drain until it stops. Then I can remove the filter without a bath. Anything else results in an oil spill....
#59
This is getting to be like an argument between pro gun folks and the Anti gunners. If you agree with our God given right to carry, then carry. If you don't believe in defending yourself, then DON'T. But don't force your views on me.
Back to the point: If you want to pre drain the oil filter, do it. And then have to wait for it to drain out.
If you don't do that like me, put a newspaper under the drain pan, have on rubber gloves, loosen up the oil filter and try to carefully take it off to drop it in the oil pan.
One way is longer and cleaner. The other way is faster and dirtier.
It's your truck, your oil, your driveway or garage floor, you decide.
