3525 lbs/tire (load range D) - is that enough for a F350?
#31
#32
The spec on my F350 stock diesel tires for the Michelin LTX A/T2 in 275/65R20 is 3750@80psi which is 7500 total for the GAWR of 7230lb. The Toyo's will give you 7050lbs total of the 7230lb GAWR (180lb shy).
Again - they will work (not at maximum loads) as long as you know what you're going to be towing you're good
MAHinton
03-10-2002 09:09 PM
