Checking my timing job please help
Old 08-15-2018, 10:12 PM
5.43v's Avatar
5.43v
5.43v is offline
OK so I took my cam phasers off re did everything and had cylinder 1 at TDC with the valves closed. I put everything all back together, marks all lined up. So is this all correct? So I rotated the crank shaft and none of the marks ever line up again. Please explain, I don't want to button up the cover then have it explode
Old 08-15-2018, 11:52 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4
07F150Lariat5.4 is offline
That is normal. It takes many revs (don't know the exact number of revs) before they line back up again. As long as it was lined up properly initially, then you're set.
Old 08-16-2018, 07:01 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
Its 122 revs not practical to do
You should turn crank by hand 2 full revs clockwise to prove no valve to piston contact . Before you moved her she should have looked like this .
Old 08-16-2018, 09:22 PM
5.43v's Avatar
5.43v
5.43v is offline
OK fingers crossed I'm going to turn it over tomorrow morning. That's good math to figure out 122. When I took it apart I hardly remember turning the crank until I got the marks to show up on the cam. The chain was all worn out and the guide was broken so I think the chain skipped and the timing was off.. It had stopped running after driving like crap
Old 08-17-2018, 10:17 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
It takes something upwards of like 25 revolutions before the timing marks line up again.
KenReb
Modular V10 (6.8l)
12-24-2017 04:30 PM
F500Mike
03-27-2013 10:43 PM
tmm313psu
2004 - 2008 F150
03-31-2010 09:32 AM
big block power
01-07-2003 10:09 PM
d1a2n3e
09-21-2002 12:57 PM
Quick Reply: Checking my timing job please help
