What did you do to your Superduty today? 2019 version
#196
Tomorrow will be 3 months since I traded in my 2004 lariat and drove off in my xl. Nothing like a few mods to help you forget about the old ride.
husky floor mats
huskey under seat storage bin
built rite rear seat latch
rear wheel well liners
weather tech window and hood guards
Abs research bed step 2
tac 6 inch drop hitch step
westin bed mat
westin hd ladder rack
Weather guard pork chop box
highway products guardian rack,bed rails, 5th wheel box
need to up grade the wheels
husky floor mats
westin bed mat
Truck looks like it's set up for some work - nice setup
#197
When you cut your air dam did you cut straight across the bottom or taper/angle it up towards the edges?
#198
I finally made a decision on what bed cover I wanted to go with. I went with the Bak Revolver X4. Really like the looks of it. Seems really secure. Wont know about being water resistant until probably saturday when we expect rain. However, I like it. Next up is wheels and tires and looking at leveling kits.
#199
I made a mark at the locations where the bumper comes back down so its pretty much staight in the center and then measured up at the ends so it goes up slightly from the 2 center points. Measure up 4 1/4 at all 4 spots. Used painters tape between the 4 points for my edge.
#200
#201
#202
#203
Mine makes a couple loud cracking noises. I also get leaks at both ends of the cover (tailgate and up against the front of the bed). The reality is I think this cover could be another inch longer and it would work much better. I have the BakBox 2 as well and I'm on my 3rd one since August. They just fall apart when running down the road (7,600 miles on the truck).
I'm not a fan of my X4 or of the Bakbox 2. I sure hope you have better luck with yours! I do really like the concept and design, but I feel that it needs another $500 worth of quality installed in it. I'm biased though b/c my last truck's cover was a Retrax Pro and that thing was amazing.
#204
#205
#206
Installed Amp bed side step on each side, stuck on my tailgate inserts from BD Trims, fuel filter changes, cabin air filter change and about to go back out to the truck to finally use forscan to get rid of the double honk and a few more changes. Even had time to give it a quick rinse. I also removed the backseats the other day to build a storage box in the backseat. A big storage box. If anyone wants a picture of the backseat removed, let me know. I’m building the box on the weekend.
#208
#210
