390 connecting rods
390 connecting rods
Ok we are just cleaning up some , what we believe are 390 connecting rods, (for wedding reception decor.)
and we came across one that has a copper tone to it. so far all the others are not like this.
casting numbers on one side are C6AE-C on the other side, from the piston side down are 72 L B24
Why would it be copper toned and appears to be cast soild, not just a coating??
The bolts for the connecting rod cap, look to be 3/8 fine thread and neck down to .346 dia.
just looking for more information
There was a thread talking about this long ago.
https://www.ford-trucks.com/forums/1...or-damage.html
Not sure if the other links still work.
The rods are forged steel, the copper you see is probably "plating" to bring up a weight or thickness spec that was just out of the margins. Another reference, similar to the prior post links, from Barry Rabotnick's FE book, caption right side bottom of page 56:
https://books.google.com/books?id=q_VeDwAAQBAJ&pg=PA56&lpg=PA56&dq=copper+c olored+ford+fe+rods&source=bl&ots=8SfbJAdbnU&sig=X VLKjlNJ4GnMCfk5m1-rmgtVxnM&hl=en&sa=X&ved=2ahUKEwjAieHB1-3cAhVQIqwKHcuwAaQQ6AEwFXoECAsQAQ#v=onepage&q=coppe r%20colored%20ford%20fe%20rods&f=false
colnago
25
05-26-2018 01:02 AM
peckade
11-16-2009 10:27 PM
hoxiii
09-05-2006 04:02 PM
nate5812
04-21-2005 04:51 PM
joegeoghegan317
11-26-2004 11:56 AM
