1949 F5 School Bus Brake 5 socket (lines) manifold
For what it is worth, if you have trouble locating one, you can likely plumb an equivalent with a slew of fittings:
https://www.ford-trucks.com/forums/1...l#post16544498
I assume you are using a booster? No? I had the part you are seeking. It's like a cast iron slug that hangs off the end of the master cylinder. I found it to be quite problematic (came loose easily) and redundant, so I tossed it. You really don't need it anyway. All you need is a line from the master cylinder to the booster (you can tee in a hydraulic stop light switch here or use the 1/8" NPT adapter at the master cylinder, or use a mechanical stoplight switch), and then just hang a brass triple tee adapter on the brake booster to feed the two front and single rear brake lines. All of a sudden I can't find the pic of my installation, they've been deleted from my albums. Sorry. I'll take some more.
Welcome to FTE. I'm in Pasadena so we are practically neighbors. But I digress.
I can't tell for sure from your pictures, but it appears you have "Widow Maker" wheels. Very common for that vehicle, clear into the late 1960s. These are unsafe at any speed. No one will work on them.
Your 5 lug pattern will present an issue finding replacement wheels. There is a wealth of info in several threads in the "Large Truck" forum. I will post a link or two. Good luck with it!
Post 4 here is an example. Truckdog has the number on the wheel situation, and there are more threads on the subject as well.
https://www.ford-trucks.com/forums/1...-pictures.html
