Anyone regret getting a 6.2l?
#31
I am also from Michigan. I have a 10k lbs bumper pull camper and a 17 F350 6.2L with the 4:30. I've played around with the gas mileage at several different speeds. Setting the cruise on I-94 at 70 mph, I get 15 mpg, setting the cruise at 82 mph gets about 11 mpg and towing the camper at 65 mph gets about 9 mpg. I've towed from Flint up to Boyne mostly on I-75, again at 65 mph, and get about 8 mpg and then I've driven that same route with no trailer following someone going 85+ mph and gotten about 7 mpg. Most Michiganders know of the slight hills on I-75 around West Branch, and my setup while towing under cruise control pulled up that hill mostly in 5th gear and slipped down into 4th or 3rd to get back up to speed because of the lag with cruise control. Most of the trip on I-75 while towing it stays in 6th gear with the occasional drop to 5th gear, I've never found the need to lock out 6th. Very happy with the 6.2L, no regrets.
#32
Great info man...you make the same drive as me when towing. For refference Im towing a 32ft TT 7500lb range with my 16 F150 max tow 3.5l. I get around 9mpg towing at 70mph up 75. As low as 8.5 and as high as 9.5 on the computer. Hand calculated it always seems to be about .4-.5mpg less then computer. If I do 80 cruise with a dirt bike in the bed I get around 19mpg on the highway up to west branch. Im in 6th most the time (1800 rpm range) even slight climbs and bigger climbs jumps into 5th (2300 range), and biggger climbs 4( 2800 rpm range). Did you consider the 3.73s at all?
Any bump steer on your truck at all?
I did consider the 3.73s but never test drove it, so can't tell you my opinion on the difference. I read a lot on this forum and decided to get the 4.30, and when I tow, the truck gets up to speed on the freeway just fine. Also, I do get some bump steer on big bumps or pot holes but the 15 F150 I had would have the rear end skip around on the same spots. I've had a few that scared the crap out of me when it happens on a curve on the freeway, but generally it's a pretty smooth ride.
#33
I did pull the same trailer with the F150 and that's why I now have the F350. The F150 never felt under-powered with my camper but the ride was usually white knuckled. I put timbrens on the F150 and it helped level it out, but it just didn't feel planted and I had a lot of sway. It was never comfortable to drive over about 60 mph. I didn't have the max tow package on the F150 and I figured out after towing a few times that I was over the axle rating and the payload rating. I still use a WD hitch with the F350 and it is so stable I can drive with 2 fingers on the steering wheel.
#34
No one ever mentions the added safety benefit of the additional 700+ pounds of engine in front of you with the diesel. Or the less volatile fuel inherent with diesel. Sure it cost about $9000 more, but resale historically has been higher. And really for the private owner that has the means to purchase a $60,000+ truck, does a few hundred more dollars per year for maintenance matter that much? You buy a truck to haul or tow...considerably more horsepower and over double the torque...seriously most of us prefer the diesel!
#35
#36
No regrets at all. The 6.2 still surprises me with how much power it has. The spare payload and probably slightly better ride is a bonus. Pulls my 11,200 GVWR camper very well. It is highly unlikely I will ever own a diesel truck, just not enough of a gap in performance with the big power of the gas engines.
#37
so this is interesting. I only tow a 7500lb trailer but mine is max tow package. I think my payload rating is like 1900lb range. I hardly ever get sway...but do get a little push sometime if a big truck/suv goes past me on the highway...no where near as bad as any other half ton I have owned in the past. Curious what your payload rating is on the 350...serious capacity being gas!
#38
#39
Only regret was holding on the the Tundra for so long!
After towing TT and hauling tractor with Tundra the queasy stomach and white knuckles just took me over the edge to deal with it.
Now, I just grin and haul! Will not enter into gasser vs. oil burner debate it's a personal thing to each their own need.
But second year of the new gen SD and am just looking for a reason to hook up trailer and go shred pastures now!
#40
I moved to the 6.2 from a 5.4 09 F150; first I moved to a 2011 250 XLT w/6.2 and then on to my current 2017 F250 w/6.2. I only tow my Jeep on a car hauler, so not a lot of weight, but the entire platform is a dream to tow with, and to just drive for that matter. I suspect if I end up with a two jeep hauler for my and my son's Jeep, I will still keep the 17 w/6.2.
#41
Lots of us from mitten on here it seems. I had a '13 f150, fx4 with the hd package as well. It towed my GVWR 7800# TT with little sway and no real problems on I-75. I did get blown around approaching mackinaw on what i thought wasn't a windy day. Talk about white knuckle. The payload in my truck was 1500# which I am sure that I was close to using all of it, wife, dogs, bikes, etc.
I just bought a 6.2, 3.73 F350 XLT. I must say I am loving the truck, I thought about the diesel but just couldn't justify it. My payload is 4169#! I haven't been able to tow with it yet, but I am looking forward to towing instead of sort of dreading it.
#42
Yes, sometimes.
The 6.2 has been a great engine, it's never been unable to do what I've asked, but towing my 7500 lb TT it leaves a little to be desired.
The fuel economy is the major irritant. 7.8-8.5 is standard on the interstate, sometimes in the 9 MPG range when driving on two lanes. This means I get ~280 miles before starting to look for places to stop. On the good side, the 6.2 has a fantastic exhaust note and when cruising along at 3500 RPM it sounds like a sweet song, not a wheezing engine.
Resale is the second irritant. I almost traded on a 2018 Dmax last week, the dealer offered 43k on the trade. He said if it was the 6.7 he'd give me 51k, so there's the difference in the purchase price right away.
I strongly discount the comments about 6.7 durability, I see dozens of these on the road daily and haven't yet talked to anyone with a problem. The 6.0 and 6.4 is a different story.
#43
Yes, sometimes.
#44
These trucks are dang expensive, I've seen houses cost less. the thought of the F350 with the 6.7 with options I wanted versus a F250/6.2 - and the F250 had ample payload reserve to pull our 5ver. With the price diff, I can buy a very nice ATV, and I luv the sound of that 6.2 exhaust.. I enjoy having the 6.2 and a few more toys..
I can see the need for a 6.7 in some cases, but I see a lot of them towing nothing, and not earning there keep. That's a lot of money to spend on power never used, unless you drive over 25K miles a year, and keep it forever.
