Carbon build up around plugs - Ford Truck Enthusiasts Forums
Old 08-12-2018, 10:44 PM
5.43v
5.43v is offline
5.43v is starting off with a positive reputation.
Hey all, looking for advice. I recently pulled out 5 broken plugs. Before I replace them do I try to clean out the carbon in the plug hole that's left over with a wire brush? Any advice is welcome
Old 08-12-2018, 10:56 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
Take it you didn't use a impact to remove them? It almost eliminates breakage. The carbon can be cleaned with a .410 bore brush. Make sure you use nickel anti sieze.
Old 08-13-2018, 05:18 AM
redfishtd
redfishtd is offline
redfishtd is starting off with a positive reputation.
Yes clean that carbon out and return it to new condition
Carb cleaner will dissolve it . Carbon breaks plugs coming out and going in . It changes heat range of plug . Make sure you torque wrench them in 25-28 foot pounds not by feel . They will last 60k if you take care . These plugs are hard to get to. Start by fingers it should feel right . Use rubber spark plug socket . Most 5.4 3v use the newest sp 546 . Unless you are in the head redesign around 08. Check your vin for that .
By all means replace all boots and use dielectric grease sparingly on boot ends , it is an insulator not a conducive gel . Clean all cop ends and connectors . Replace any connector not locking on . Put a little anti seize on cop bolt ,it must hold cop good .
Of course you blew out all dirt before starting job so it doesn't end up in cyl .
Anti seize on plugs no longer required but if you do use it don't use copper on an alum head. Nickel is on amazon and is for very high heat, use it sparingly and it will last you for years . Ford specs nickel .
Old 08-13-2018, 10:08 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
I prefer to use a spark plug thread chaser to clean the hole because it also fixes any issues with the threads at the same time.
Old 08-13-2018, 10:36 AM
5.43v
5.43v is offline
The carbon build up I'm referring to is inside the head past the threads. Ford's spark plug uses a long thin plug to make up for the extra large valve.
So ok back to the carb cleaner do I spray it down the hole then blow out the cylinder?
Old 08-13-2018, 06:56 PM
redfishtd
Some use a 410 bore brush . Some make up a wire like a bore wad cleaner . Just make sure it can't end up in cyl . Carb claener will evap readily if you give it time .
Ford uses it on old type sticking plugs/carbon seized to try and get past threads . Its not an exact science . Carb cleaner actually melts carbon .
Old 08-13-2018, 08:50 PM
5.43v
5.43v is offline
Excellent thanks
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
