Shorten Brake Pedal ?
Old 08-12-2018, 10:15 PM
Pokee's Avatar
Pokee
Pokee is offline
Has anyone cut and shortened there 1950 F1 brake pedal? I have stock brake pedal with the power brake conversion and thought about cutting and shortening the brake pedal so it does not stick up so high. I shortened the linkage where the pedal connects but I would like it a little shorter.
Old 08-13-2018, 12:40 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Shorten them all the time...power brakes do not require as long a throw on the brake pedal
Old 08-13-2018, 05:01 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Yes, I have shortened brake pedals. You can also change the pedal angle for better comfort when you weld it back together.
Old 08-13-2018, 07:03 AM
artscott61's Avatar
artscott61
artscott61 is offline
Shortened mine 55 f-100 I was worried about bottoming out on bleeding but it works fine. I need to cut it again and weld at a different angle to get further away from the steering column .
Old 08-13-2018, 11:07 AM
Pokee's Avatar
Pokee
Pokee is offline
Thank you for your response. That will be another project to do.
pomial
1997-2006 Expedition & Navigator
16
09-01-2009 11:18 PM
triggerjoe
04-25-2004 03:55 AM
dbrick
04-18-2002 03:58 PM
Quick Reply: Shorten Brake Pedal ?
