Tuning with EZ link, where does stock tune go? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 08-12-2018, 04:00 PM
Crazy03
Crazy03 is offline
Crazy03 is starting off with a positive reputation.
Hello so for those who have deleted and tuned your truck I have a few questions? I have a 17 f250 that I put a 5 inch straight pipe exhaust from AFE and their intake on. I bought a EZ link from No Limit with the Tyrant tunes. So I have a couple questions if you could answer them.
1. Where does my stock tune go, I hope it doesnít dissapear, if so Iíll be so pissed?
2. I have the SOTF switch so I installed a tyrant tune and then trans tune but seems that it shows on the EZ link that only one can be installed and kept at the same time? Maybe I donít know what Iím looking at?
Thank you for any help!
Old 08-12-2018, 04:30 PM
swlakingranch's Avatar
swlakingranch
swlakingranch is offline
swlakingranch is starting off with a positive reputation.
1. Your stock tune does not disappear. It is stored, if you open the app and look in the available profiles I think it says return to stock.
2. My truck is the same way ez lynk only shows that the tcm is installed but the ecm tune is installed. If the ecm tune was not installed it would not run right. I don't know why it does not show to be installed in the app.
Old 08-12-2018, 07:11 PM
Crazy03
Crazy03 is offline
I didnít see the stock tune anywhere but maybe Iím not looking in the right place. I reinstalled the tune for the motor because I figured Iíd rather have that then the trans when I went to start it, didnít want a light show in my face for all the codes. Iíll call no limit tomorrow and see what they say. Thanks for the reply
Old 08-12-2018, 07:23 PM
roadpilot
roadpilot is offline
roadpilot is gaining momentum as a positive member of FTE.roadpilot is gaining momentum as a positive member of FTE.
Can't speak for the EZ Lynk, but when I first tuned my Mustang, the tuner saved the stock tune on the device so that you could apply the stock tune if you wanted.
Old 08-12-2018, 07:55 PM
Crazy03
Crazy03 is offline
Every car or truck I have ever tuned, the stock tune is saved, I really hope Ez link saves it or the product would be horrible. We shall see
Old 08-12-2018, 08:43 PM
2017-350's Avatar
2017-350
2017-350 is offline
2017-350 is starting off with a positive reputation.
Does anyone have the instructions for the SOTF? I installed my delete today but canít find anything beyond a 2016 super duty for the switch. Thanks.
Old 08-12-2018, 08:53 PM
Crazy03
Crazy03 is offline
Which portion do you need help with just finished my install today. The only issue I had was where to plug the switch into because the instructions that were sent were for older year trucks. I actually asked on another post where to plug in and it was answered! Anything I can do to help I will
Old 08-12-2018, 09:06 PM
2017-350's Avatar
2017-350
2017-350 is offline
I keep getting code P0183. I wired it where the orange is on the bottom corner and the tan is directly next to it like for the 2016 year model. Iím stumped on why I keep getting the code
Old 08-12-2018, 09:07 PM
0835064
0835064 is offline
0835064 is starting off with a positive reputation.
It doesnít save the stock tune, it uses a generic stock tune from the cloud.
Old 08-12-2018, 09:14 PM
Crazy03
Crazy03 is offline
The plug with nothing in it is the plug you use to plug into the harness from the kit
Another view
Old 08-12-2018, 09:16 PM
Crazy03
Crazy03 is offline
Ok I just hope when I return it to stock there are no issues, thank you
Old 08-12-2018, 09:19 PM
0835064
0835064 is offline
Itíll work fine just wonít be what came on the truck
Old 08-12-2018, 09:22 PM
2017-350's Avatar
2017-350
2017-350 is offline
My sotf plug doesn’t match the one you’re hooking to in the picture
Old 08-12-2018, 09:33 PM
Crazy03
Crazy03 is offline
Old 08-12-2018, 09:34 PM
Crazy03
Crazy03 is offline
This is the plug that came with my kit? I have a 2017, either I have the wrong one or you do?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
