hey guys looking for some reconditions on where to start after I get truck towed home. I was driving and lost all acceleration power. Couldn’t do more then 20mph. Pulled in checked a few things and fired back up started running really rough again. Took battery off for about 10 min put back on and worked for about 1000 feet and did the same thing. My scanner wouldn’t read anythibg so my brother went and got his and had to run a test to get anything. These codes popped up. Any hints on where to start to try and fix the problem. All help greatly appreciated thanks
So finally used a better computer. Did a buzz test on the injectors and everything checked out. But this scanner showed me a new code of p1316 which is injector circuit/ idm code. Do you think this could be the issue?
