International / Ford Engineer better pray I don’t meet him in a dark alley.
Old 08-27-2018, 10:26 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Good idea. Go easy with it when you tighten. Can over tighten and screw up the seal just as bad as it being loose.
  #47
Old 08-28-2018, 07:52 PM
F350-6's Avatar
F350-6
F350-6 is offline
Originally Posted by ExPACamper
Yeppers! I haven't seen how to change the oring (without a $300 kit) ?
I had a heck of a time with the dipstick bracket the first time, but after repeated removal, it is quite simple....Is weekly too often to remove it? LOL.
This is one of the early versions. https://www.ford-trucks.com/forums/6...with-pics.html
Granted it's an old thread. Most folks switched to using a .45 caliber bore brush instead of the plastic rod. For that matter, you can just buy the kit with all the parts you need, a brush, and the instructions for around $50 from Bob. Oil Level Gauge Adapter Repair Kit for 1994 - 2003
Much cheaper than the $300, and no need to drop the oil pan.
  #48
Old 08-28-2018, 07:55 PM
F350-6's Avatar
F350-6
F350-6 is offline
This thread might also be a good place to remind some of our newer members of the things we've learned over the years. A special thanks goes out to Springer Pop for keeping Alan's old site links around for the rest of us to still use. And don't forget to look at Guzzle's (the same Bob from Diesel O Rings) page, which is in the list.
Powerstroke Mods and Maintenance
  #49
Old 08-29-2018, 08:41 AM
Firefighter 1406
Great post Chris. Thank you for adding that link.
  #50
Old 08-29-2018, 09:34 AM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
Thanks! I don't know if I have a leak, but have been moving that thing around like a palm tree in a tropical storm. I'll be sure to check it.
hch60
12-23-2014 06:29 PM
cutthroatxxx
09-08-2014 12:37 AM
carbon coupe
02-08-2014 04:41 PM
DKW 86
09-01-2010 10:32 PM
rednekrebel28
05-11-2010 09:27 PM
Quick Reply: International / Ford Engineer better pray I don’t meet him in a dark alley.
