International / Ford Engineer better pray I don’t meet him in a dark alley.
1. Oil pan dipstick tube adapter o-ring
2. Stock upper rad hose through the belt
3. Factory aluminum t stat housing
4. Hub/bearing assembly
5. Vacuum actuated auto locking hubs
6. Non-serviceable Idle Validation Switch
7. A locking system that is a thief's dream
8. No factory installed zerk fitting to grease the slip yolk
9. Battery cable clamps
Luckily, all these can be can be improved with the vast aftermarket vendor support we still have today. End of the day, it's still Built Ford Tough.
If you ever met them, they would probably take your hand and walk you over to a 6.4 engine stuffed in one of those trucks and ask again what your complaints were while they pointed out those parts on a 6.4.
The first time I saw one of those, I thought I bet I could pitch a handful of marbles under the hood and I'd be surprised if 3 of them made it to the ground. The 6.0 had issues too. How about pulling the FICM, coolant reservoir, CAC tubes, turbo, oil filter housing, and EGR just to get to the HPOP?
You should look at the 7.3 as glass half full.
Besides its all for fun anyways.
on
I am quite happy with my LEV Excursion, sans CAT/EGR/DEF/etc.
#28
... snipped ... One of the things you're not considering is: these units were never designed for Pick-Up Trucks. If you've ever worked on a Bus or similar you would think they were a breeze. These are so down tuned you wouldn't believe it. For the time, these were the Workhorse of the Industry. I.H. made a Fortune!
#29
I've read this kind of comment before. How were the buses or other vehicles "tuned more" i.e. what were the main differences between the pickup truck 7.3 engines and the ones the other vehicles got? Silly me but it seems to make sense that all one had to do was to replace the "untuned" bits on our pickups with the "tuned" bits from the other vehicles, then we too would have "tuned" 7.3 mills. What am I missing?
Then there's little things like
- 200g fuel tanks without screens in them needing the H&H.
- More room under bus/dump truck hoods for bigger way better than our stock air intakes and bigger air filters (possibly 6637 sized).
- Room for the larger turbo ( was it D66? )
- lower gearing than 3.73;
- non-Ford warranty guaranteeing, defueled for mpg wars, "safe" pcm programming for more power
- No wastegate
Which is pretty much the basic nearly required stuff we all do anyways once we get our new to us 7.3's with nearly every "mod" giving us more SOTP power
#30
Subscribed! I love my 7.3 and plan to add three more to the stable in the next few years, but some of these problems are great to know about before I get to them.
I'll add that the springs don't seem heavy duty enough in the front to handle the weight of the engine.
Tie rod ends seem to go out often.
Brakes drag or freeze up
