Mass Air conversion for dummies??
Old Aug 10, 2018 | 12:23 AM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
I will start out by saying i have spent more than a couple hours this week over several nights with the search button, dragging up old threads. I have yet to find a clear answer.
I have a 1992 F250, 2wd, reg cab longbox. it came from the factory with a 351W, E4od, and a speed density system. Two of those pieces are gone, and maybe, the speed density needs to go as well. The truck is undergoing quite a bit of work, and that includes a much more aggressive 351W, (9.75 to 1 compression, a lot of head porting, a healthy cam, headers, etc) and a ZF5 transmission.
I have no donor truck to pull a mass air system out of, and i fully understand that my ECM from the original truck wont work, so I'm thinking right now may be a good time to start fresh, and look at this Mass Air conversion setup. I understand ford used to make a setup, but doesn't anymore. Some say you can build a harness, but i have yet to see any plans. I'm looking for someone with much more experience in this than I have to say "hey, look at this, do it this way!" so I can make a educated move towards a mass air system in my truck.
Thank you for your time, everyone.
Lee
Old Aug 10, 2018 | 07:48 AM
Scndsin's Avatar
Scndsin
I did the harder bit with an E4OD so doing a manual should be a breeze.
I used some spare wires from a salvaged harness to create a stand alone injector/engine harness that plugged in, but most will tell you to just add/build an overlay like the Motorsports harness.
Use the old ford fuel injection info with whatever ETV diagrams you can find to make up your own build plan.
I'm guessing you'll have to go with at least a 94 5.0 ecu unless you can find a Cali spec 5.8
Most say that an auto ecu will work just as well as a manual ecu.
Hope this is a start for you:
https://www.ford-trucks.com/forums/1...5-to-c101.html
Look at post #11, connector C-185 for your primary checklist
Pat Kolb
1978 - 1996 Big Bronco
Nov 7, 2011 10:07 PM
NSMITH1987
Jan 1, 2008 02:05 PM
tomtrevino
Oct 7, 2006 09:11 PM
Scndsin
Jun 19, 2006 11:38 PM
FosterJoshua
36
Jun 21, 2005 10:43 PM
