F450 Driver side tire sticking out more then passenger? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 08-09-2018, 07:23 PM
e6bailey
e6bailey is offline
e6bailey is starting off with a positive reputation.
I just got home from getting some Toyo M920 245/70/19.5 installed on my F450. Is this normal to have the driver side stick out more the the passenger. It is about a 1Ē difference with the tires straight.
Itís really throwing me off and looks out of place to me.
Old 08-09-2018, 07:27 PM
TXSD6.2
TXSD6.2 is offline
TXSD6.2 is starting off with a positive reputation.
The front axle can get thrown off (one side sticking out more than the other) when leveling or lifting the truck and not relocating the track bar or installing an adjustable one. Is yours stock up front?
How is the rear? My 2018 F250 SRW CCSB passenger side rear wheel sticks out 1.5" more than the other side (very noticeable with larger tires). It really aggravates the the 'ole truck OCD to look at.
Old 08-09-2018, 07:33 PM
e6bailey
e6bailey is offline
Yes it is stock all around. The back looks even.
I didnít do any lift or anything crazy on this just truck to avoid these issues.
Old 08-09-2018, 07:44 PM
Ricohman's Avatar
Ricohman
Ricohman is offline
Ricohman has a good reputation on FTE.Ricohman has a good reputation on FTE.
Mine is about the same. It's normal.
The axle moves forward and to the passenger side under compression.
Old 08-09-2018, 08:19 PM
cficare's Avatar
cficare
cficare is offline
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
Hard to tell front the pix, but your bumper may not be exactly centered. If true, then your cab (along with fenders & hood) could be adjusted sideways. There is a 12 month / 12K mile warranty period for "adjustments" such as that. I just had my cab moved to the left about 3/8" inch to center it with the bed (my bed had no adjustment left to move it to the right). Actually they rotated my cab because it was already centered about the front bumper. Dropped the truck off at my dealer's body shop at 9AM and they were done by 10:15AM.
Old 08-10-2018, 12:58 AM
willynilly
willynilly is offline
willynilly is gaining momentum as a positive member of FTE.
just get under there with tape measure and see if its the cab or axle thats off. cab can be moved easy with simple hand tools. no lateral adjustment of the axle without adjustable trackbar.
Old 08-10-2018, 09:19 AM
e6bailey
e6bailey is offline
Not exactly sure where to measure for the cab but itís seems like it could be off by 1/4 not enough to completely make up the difference. Thanks for the input.
Old 08-10-2018, 12:16 PM
HST
HST is offline
HST is starting off with a positive reputation.
Pretty sure Ford uses one track bar bracket for all the SD trucks. Your F450 probably has a taller HD springs so that alone will shift the axle sightly to the drivers side. As the distance from the axle to the truck go up, the axle pushes slightly more to the drivers side. I have 1.5" leveling coils and mine shifted about 3/4" to the drivers side.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
