How many miles before CAC cold side failure?
I'm curious if there is an expected lifetime of the cold side tube. Those who have had the failure can you post how many miles you had when it failed and if you were still stock? My 2014 is at 32k miles and I've started towing a 13k lb 5th wheel. With the 5th wheel I'm seeing higher boost levels than I did with the lighter travel trailer so I'm thinking I better do the upgrade but I'm wondering how urgent it is.
Mileage will vary. These aren't failing in huge numbers, just that some do fail. Some mass produced batches will be better than others.
Mine survived 96,000 miles with nothing higher than stock boost.
I put a new OEM on it and am not concerned. If it does break apart, then it'll be a lesson learned and I'll go with a recommended aftermarket from here.
I had 39,500 on mine when it blew. Monty had about 22k on his. The odds are yours won't blow but for the low cost of a quality replacement, it's just not worth the risk to me. Whenever I'm towing through someplace really hairy like NYC on I95 or Chicago at rush hour on I90 I think about when mine failed and how lucky I was with location. It could have been downright dangerous to me and my truck/RV if it happened at the wrong place. Even at night or in the pouring rain would have sucked.
Received 6,671 Likes
on
I've only had this truck for a couple months. My son works at a local diesel shop and looked it over when I got it. He told me it's about to fail. I carried a band clamp with me just in case. Dealer replaced it free of charge under factory warranty. It has 44,000 miles on it. It's a good idea to just replace if you see signs. Ford usually covers it. It's no fun to be hooked up to a camper and blow one. I have seen that!
156,000 miles on mine. I have the truck down for some work. With all the talk of CAC failures recently I inspected both sides of the cold pipe a few days ago and see nothing that shows any weakness. No hairline cracks, stretch marks, ect. Everything looks good to me.
That said, it is higher on my list of upgrades in the future than some other things.
My 2013 F-350 blew at 81,000. The consensus here was that it isn't all that common, the local dealership that replaced it under warranty said the same. Less than 6 months later, the one on my 2012 F-550 blew. Think and do what you want. H&S already on the F-550, ordering one for the F-350.....
MK, Just curious, how could your son tell it was about to fail? I did not see any issues with mine the weekend before it blew.
I would also like to hear about the warning signs to look for on the pipe. I'm glad to hear that the odds of it failing are relatively low but as its been pointed out when it fails it will likely not be in a good place or time. I will be replacing it for piece of mind while towing on a trip if for nothing else. Thanks!
