Your truck is not recommended for truck camper
Hello forum,
I just bought a 2018 F350 DRW 14k GVWR, with a 5600 lb payload rating (diesel, 4x4, crew cab & long bed sure reduce the payload!). Going through the owner's manual I found a folded sheet of paper that states:"Your pickup is not recommended for carrying (a) slide-in camper". It then goes on to explain how to match and load the camper. Hmm. It's the only document we didn't review during the sales process. Hmm again. I just spoke with the sales guy and he says that's just FORD's CYA boilerplate. However, the document references my VIN, so it's vehicle-specific.
The truck did not come with the "Camper Package" (it was existing inventory) but it has the rear auxiliary springs and stabilizer bar, so unless it's missing the heavy service front springs (hard to imagine for a 14k GVWR diesel), the only difference would be the "Slide-in camper certification", whatever that is.
Did anyone else receive this document (7U5A-061B82-AA) for their truck that did NOT include the disclaimer?
Thanks!
Nick
Thanks!
Nick
The following users liked this post:
The camper certification for our 2017 F350 with the optional camper package is attached. As noted, the cert is indeed vehicle specific as maximum loads and center-of-gravity window is calculated based on specific vehicle configuration.
The camper package availability is not universal; there are several configurations -- including the F350 DRW -- for which it's not offered.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Short answer is I don't know, but the Ford specs say "Camper Package (Option Code 471) required with F-250/F-350/F-450 Super Duty® " in the section on slide-in campers. I bet that is why.
You can see it here - https://www.ford.com/cmslibs/content...tyPU_Nov27.pdf
Received 6,667 Likes
on
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Thanks for the document - that's just what I was looking for. I ran Ford's online configuration tool for my 2018 vehicle and it allows me to select the camper package; do you think the restriction was only for 2017?
Thanks for the link; that's very helpful. I downloaded the Super Duty brochure and thought all the info was in the payload matrix. You're probably right about the lack of the camper package option. I can't imagine my truck isn't similarly configured, but without the calculations.
Nick
Same restrictions for the 2018. Which wheels and axle ratio are on your truck?
Also, what is your truck’s front GAWR? If it’s 5990 lbs. then it’s my understanding that your truck is already at the maximum standard front spring rating. Check the cert label on the driver side B pillar.
Regards,
Jim / crewzer
Regards,
Jim / crewzer
The front GAWR is 5600 lbs. The wheels are 17" (with 245/75 Michelins). Axle ratio is 4.1.
Where do you see the camper package restriction for DRW? In the PDF that RV_Tech linked to there's a footnote for F350 that says the camper package is required, and it lists a 4956 lb payload for 4x4 DRW Crew Cab diesel. I don't see any other modifiers.
Nick
Nick,
Well, 5600 lbs. FGAWR isn’t the maximum standard, but it’s close.
The restrictions are described in the package content snip above; my understanding is that they apply to SRWs and DRWs.
Ford says the camper package (including the cert) is required to carry campers of the weights listed, but the CP is not avalaible with all configurations or options. For example, if a customer wants the factory camper package, then he/she can’t order 20” wheels and tires.
iMHO, the truck-specific cert serves two useful purposes: It lists truck- and application-specific camper weight limitations (and associated assumptions), and it helps to correctly locate the camper’s center of gravity fore and aft in the truck bed. You don’t want the camper CoG behind the rear axle because this multiplies rear axle load and reduces front axle load. You also don’t want the CoG too far ahead of the rear axle because you don’t want to overload the front suspension. The cert can help you locate the COG “just right”, although you can do essentially the same thing via trial and error at a CAT scale.
Our old truck’s cert illustrated that a camper’s CoG had to be located in a fairly narrow 15” band in order to carry the maximum camper weight of 3111lbs. This spec included 5 x 150 = 750 lbs. allowance for people and cargo in our truck’s passenger compartment.
Additionally, the truck camper manufacturer should be able to provide “as built” CoG data for their campers, although these specs may be based on otherwise empty weights. Loading the camper may (will?) affect the CoG location to some degree.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
on
on
Sweet! That's what I'll do then. If I approached the dealer on this I would get a "deer in headlights" look.
Nick,
HTH,
Jim / crewzer
HTH,
Jim / crewzer
By "close to maximum standard", you mean that my FGAWR is almost as good as it gets, right? I don't see anything in my options that would disallow the camper option (and 20" wheels can't even be selected).
The CG is marked on my camper; if I load it all the way into the bed, the CG is 12" forward of the rear axle. For a 4000 lb camper, that would put about 270 lbs on the front axle and 3730 on the rear. I was told by the Eagle Cap dealer to have the front rubber bumpers on the TC just touch the forward end of the bed. Do you do otherwise to adjust the centering?
Nick
