Where do you mount your spare tire? - Ford Truck Enthusiasts Forums
Old 08-08-2018, 09:42 PM
collkid
collkid is online now
collkid is starting off with a positive reputation.
The factory mount on my truck sure doesn’t feel like it will hold the tire well.
Could someone post post a picture of their mount? Maybe mine is missing something?
Old 08-09-2018, 05:56 AM
frank5079's Avatar
frank5079
frank5079 is online now
frank5079 is starting off with a positive reputation.
I don't like the factory spare carrier under my truck so I got a carrier similar to this from ebay;
it's the spare carrier for an E150 van. After I finish up my 351 swap and get my truck roadworthy, I'm going to try and figure out how to mount this under my truck.
Old 08-09-2018, 07:21 AM
R&RFord's Avatar
R&RFord
R&RFord is online now
R&RFord is gaining momentum as a positive member of FTE.R&RFord is gaining momentum as a positive member of FTE.
Old 08-09-2018, 09:20 AM
Blknght22571
Blknght22571 is offline
Blknght22571 is starting off with a positive reputation.
I have the stock swing out tray under mine right now, but I'm looking at a couple of in-bed mounts on Amazon.
Old 08-09-2018, 09:33 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
It will be rough going trying to mount this with the rear fuel tank in place.... so good luck with that plan... I suppose the wrong spare tie mount will be of much more use than a dumb ole fuel tank though...
Old 08-09-2018, 09:47 AM
collkid
Is that just the one arm holding the tire up against the fuel tank?
Sure feels like the tire could easily pop out!
Stupid fuel tank.
Old 08-09-2018, 09:48 AM
collkid
This would be super cool but I have a tool box.
Old 08-09-2018, 09:54 AM
jas88's Avatar
jas88
jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Your concern about the stock spare tire holder is unfounded. Just think of how many MILLIONS of trucks Ford produced with such a mount. That thing goes back to the 60s. Not a problem.
Mount it at the rear of the bed instead of the front. I had one like that on my previous 1990 truck because it had a 32 gallon replacement tank and the tire would not fit under it:
Old 08-09-2018, 10:29 AM
GoinBoarding
GoinBoarding is online now
GoinBoarding has a good reputation on FTE.GoinBoarding has a good reputation on FTE.
My issue with the stock holder was from road salt. It got quite difficult to use. So I scrapped it, and welded a piece of chain to the front right bed bolt. That let me lock it down. Worked for a while, then I scrapped the pickup bed and went to a flatbed. I then bolted it to the headache rack. That worked most of the time, but once I started hauling a truck camper I needed the spare back in the stock location, so I built a holder with 5/8" all thread and heavy wall 1" tube. Took 14 years but the tire is back where it started. Somewhat related: I don't concretely remember the last time I needed to use the spare. I think it was four wheeling on worn out Goodyear highway tires in the CO back country over 10 years ago. Run good LT tires, know your pressures, and you'll very rarely need that spare.. Carry plugs & a compressor and that's even more true. [Now I'm sure to tear a sidewall on my next adventure!]
Old 08-09-2018, 12:07 PM
frank5079's Avatar
frank5079
The original carrier rusted on me and I have the spare in the bed. I thought about the Canadian model F150 spare carrier that mounts on the right corner of the bed by the tailgate, but I didn't like the idea of the spare tire taking up bed space...
Old 08-09-2018, 02:02 PM
collkid
That is something I thought about which is why I'm sure my mount is missing something.
Currently, my truck only has the "/" car that goes across the tire. Nothing holding it to the bar even though it looks like there were some type of mounts at some point.
Old 08-09-2018, 02:25 PM
Oneyed Goat's Avatar
Oneyed Goat
Oneyed Goat is offline
Oneyed Goat is starting off with a positive reputation.
I didn't see what year/truck you have but page 260-261 shows a bolt securing the wheel to the bar on 1996 F250/F350s:
http://www.fordservicecontent.com/Fo.../96f23og1e.pdf
Old 08-09-2018, 04:02 PM
collkid
That is super helpful thanks!
I do NOT have the wheel retainer. Looks like I'm going to hit the Junk Yards!
It is a 1990 F150 4.9L.
Old 08-09-2018, 06:05 PM
Fordtruckman_90's Avatar
Fordtruckman_90
Fordtruckman_90 is offline
Fordtruckman_90 is starting off with a positive reputation.
I have 1990 F150 with a 4.9 as well and store the spare under the bed. When I got mine, the threaded plastic tire retainer was in the cab and it was missing the bolt that threads into it. I found an OEM NOS bolt on ebay. Once I had that, I lowered the spare tire support and centered the spare, outer side of rim facing the ground, on the metal support. After that, I placed the plastic tire retainer on the inside of the rim (not the outside) and fed the bolt through the support and threaded into the retainer. Lastly, once the tire was securely mounted to the support bar, I lifted the whole thing until the slotted end aligned with the eyebolt, where I placed the flathead of the jack handle and lifted the spare until it was snug. Make sure that the eyebolt is NOT aligned with the slotted end once the tire is in the position you want it. If it is left aligned, the support bar holding the spare will fall to the ground while you are driving, or when you remove the lug wrench from the eyebolt.
Old 08-09-2018, 06:10 PM
Fordtruckman_90
This thread should help you greatly!: https://www.ford-trucks.com/forums/1...re-holder.html
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
