2014 rear chocks on a 2010? - Ford Truck Enthusiasts Forums
Old 08-08-2018, 05:19 AM
awq134's Avatar
awq134
awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
Does anyoen know if the rear shocks on a 2014 will fit on a 2010. Both trucks were 4x4, STX models, ext. cab, and had the 6.5 foot bed. Their engine was the 5.0(not sure if it matters) and mine is the 4.6. I tried comparing them on fordparts.com but wasn't having much luck finding the correct part numbers for each truck. My coworker has all of his old suspension from his 2014 f140 stx after he pur a 4 inch lift on it. I was concidering buying his rear shocks from him at a discounted price if they do in fact fit my truck.
Any help would be appreciated.
Old 08-08-2018, 07:10 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.
They will fit fine. Are you sure his old shocks are any good?
Old 08-08-2018, 06:30 PM
awq134's Avatar
awq134
awq134 is offline
I am not certain his are good or bad. Honestly, I'm not sure mine ate bad either, but am skeptical. When I hit small bumps at mild to moderate speeds i have noticed that i feel the bump multiple times. I dont recall the truck doing this in the past. My shocks show no sign of leakage, but at 97k, I'm sure they are about due to be changed. Any ideas?
Old 08-08-2018, 06:47 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
This may be of interest to you:
Shock absorber surprise
I would just use new. Shocks aren't all that expensive.
Old 08-10-2018, 05:26 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
If you have the original shocks on with 97K, I would think they are done. Time to go to Rockauto.com. I changed mine about that same mileage. The fronts had so little pressure in them that I could compress them with one hand. The rear ones were useless.
Old 08-10-2018, 04:58 PM
awq134's Avatar
awq134
awq134 is offline
I decided to buy my buddies shocks from his 2014 stx for $40. I installed them last night and went for a drive today to the local tractor supply. I was instantly able to feel a difference in the ride. No more feeling the same bump multiple times as I had been before. My original shocks still had oil in them and didn't show any signs of leaking when I removed them. What typically causes them to underperform? Dirty fluid, clogged valves, bad seals?
Old 08-11-2018, 11:54 AM
rbentnail
rbentnail is offline
rbentnail is gaining momentum as a positive member of FTE.rbentnail is gaining momentum as a positive member of FTE.
Yes, D All of the Above
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
